12 Replies Latest reply on Sep 22, 2011 5:27 AM by Harbs.
    How to handle script label JS[CS5]
    Mac_06 Level 2
      Hi All,
      Is there any way to remove existing script label before assigning a new script label to a text frame.
      I have a pretty simple script which assign script label to selected frame, It has a small palette to choose label name but there is a negative scenario where user might assign a wrong label to a frame and if try to assign once again correct label it will not override the old key, value pair but assign a second one also to the same frame. In that case our next process will a get hurdle.
      So I am looking any workaround this but not able to find out the solution since InDesign DOM won’t give any mechanism to remove the script label.
