1 Reply Latest reply on Apr 3, 2012 4:01 AM by Walter Treur
    Spark & UIImpersonator
    lndgrniker
      FlexUnit 4.1
      FlashBuilder 4.5.1
      BACKGROUND
      I'm trying to test a custom Flex 4 skinnable component, using the FlexUnit UIImpersonator class. If I run my tests from a FlashBuilder Spark only project everything works fine. If I try to test from a project with the mx component set on the buildpath I get a "getElementIndex not available in non Flex 4 projects" error.
      QUESTION
      Can I unit test spark components in FlexUnits visual test environment while still having the mx component set on the classpath?
      RESEARCH
      UIImpersonator delegates it's method calls to a "testEnvironment". The implementation used for this "testEnvironment" is decided by the VisualTestEnvironmentBuilder class and the FlexEnvironmentBuilder class. If the FlexEnvironmentBuilder class can find the "mx.core.Container" on the classpath it returns a MX environment, else a Spark environment. Only the spark environment has valid implementations for Flex 4 relevant method calls on the UIImpersonator – like the addElement method.
        • 1. Re: Spark & UIImpersonator
          Walter Treur
          I've had the same issue as well and I think it's a bug in FlexUnit.
          Here's my workaround which I've also added to the same question you've asked at stackoverflow:
          As a workaround. Just use UIImpersonator.addChild() and add a reference to mx.core.Container in your TestRunner. This ensures that a MX container is used as testEnvironment and you won't receive a 'getElementIndex...' error.
          import mx.core.Container
          public function runTests():void {
              // reference to mx container
              var containerRef:Container = new Container();
              // Run your testsuite as usual. eg:
              var core:FlexUnitCore = new FlexUnitCore();
              core.run(MyTestSuite);
