2 Replies Latest reply on Sep 22, 2011 2:51 PM by WebolutionDesigns
    Invoke CFC with Button
    WebolutionDesigns Level 1
      I have a form I built wherein I am binding several fields to one cfinput and hitting a cfc I built that pulls data from a web service. I am struggling in figuring out how to get the fields to fill in with the binding value once I click a button. Here's the scenario...the end user fills in the field, clicks a button and several other fields get filled in from the cfc that hits the web service. I have tried the following to no avail...
      <cfform id="myForm" format="html">
      <cfinput type="text" name="reporttype" id="reporttype" value="BASIC">
      <cfinput type="text" name="vin" id="vin" value="xxxxxxxxxxxxxxxxx"><br />
      <cfinput type="text" name="modelYear" value="" size="30"  bind="cfc:cfc.vinlookup.getYearvin(argVIN={vin},argReporttype={reporttype})" /><br />
      <cfinput type="button" value="getvin" name="getvin" id="getvin">
      </cfform>
      I have even tried playing with the cfajaxproxy tag and the @click event. I feel like I am close. If someone could educate me/point me in the right direction, I would appreciate it.
      ~Clay
        • 1. Re: Invoke CFC with Button
          When I add the @click in the above bind attribute, it works when I click in the appropriate fields, but I cannot seem to figure out how to run the bind when clicking the button.
          • 2. Re: Invoke CFC with Button
            ok...I figured it out and thought I would post my solution in case someone else runs into this issue...
            (my solution is based of of this link)
            cfajaxproxy tag to tie cfc to page via JSON
            <cfajaxproxy cfc="proxy" jsclassname="proxy" />
            Script that runs the method within the cfc and uses the setCallbackHandler function to return the result. The we can set the result equal to the value utilizing the DOM.
            <script>
                      function getYearvin(source) {
                                var instance = new proxy();
                                instance.setCallbackHandler(getYearvinSuccess);
                                instance.getYearvin(source);
                      function getYearvinSuccess(result) {
                                document.getElementById('year').value = result;
            </script>
            Here is the form...
            <input type="text" name="source" id="source" value="" />
            <button name="vinDecode" onClick="getYearvin(getElementById('source').value)">Get Year</button>
            <br><br>
            <input type="text" name="year" id="year" value="" />
            FYI...I wrote a quick blog post concerning this...http://webolutiondesigns.com/blog/ajaxcfcs-json-and-other-geeky-stuff/
