2 Replies Latest reply on Oct 24, 2011 6:55 PM by HaroldCHeardJr
    Formatting a SummaryField2 as a percentage
    HaroldCHeardJr
      My data is coming in via XML where SLA is either a 1=Meets SLA or a 0=Failed SLA, I then runn the field in a summay row where I average on the grouping field.  I have a SummaryField2 that I need to format the grouping field showing as a percentage.  any assistance would be appreciated.  I need to format the results in this manor "87.45%" below is the Grouping Field code below:
      <mx:GroupingField name="Customer" >
        <mx:summaries>
          <mx:SummaryRow summaryPlacement="group">
            <mx:fields>
              <mx:SummaryField2 dataField="SLA" summaryOperation="AVG" />
            </mx:fields>
          </mx:SummaryRow>
        </mx:summaries>
      </mx:GroupingField>
      <mx:AdvancedDataGridColumn id="adgSLA" dataField="SLA" headerText="SLA" textAlign="right" visible="false" />
        • 1. Re: Formatting a SummaryField2 as a percentage
          kraikit Level 2
          Have you tried implementing your own ISummaryCalculator object and providing that for the SummaryField2.summaryOperation property?
          -- Tom
          • 2. Re: Formatting a SummaryField2 as a percentage
            HaroldCHeardJr Level 1
            To solve this issue I added the "labelFunction" property to the AdvancedDataGridColumn columns like this:
            labelFunction="genericLabelFunction"
            private function genericLabelFunction(obj_data:Object, obj_AdvanceddataGridColumn:AdvancedDataGridColumn):String
                      var functionsNS:Namespace;
                      var q:QName = new QName(functionsNS, obj_AdvanceddataGridColumn.dataField);
                      var str_data:String = obj_data[q.localName.valueOf()];
                      if (obj_AdvanceddataGridColumn.dataField == "SLA")
                                if (!isNaN(Number(str_data)))
                                          var tempNumber:Number = new Number(str_data);
                                          tempNumber = tempNumber * 100;
                                          str_data = tempNumber.toFixed(2) + "%";
                      return str_data;
            I hope this helps others.
