3 Replies Latest reply on Sep 23, 2011 11:24 AM by Todd_Kopriva
    Premiere Pro CS5.5.1 Crashing on startup.
    VeriasX1
      I've perused the net for quite some time digging for a solution to this. PPro is dying right at the welcome screen. I can't even get into the program to alter anything. I've cleared preferences, uninstalled 3rd party plugins, checked vst installs, the works.
      Things I have noticed. Before failing, PPro 5.5.1 only manages to write the basic prefs file, a trace file, and the plugins loaded file. That's all that winds up in the pref directory.
      Here's the error info as it appears in the Event Viewer
      Faulting application name: Adobe Premiere Pro.exe, version: 5.5.1.0, time stamp: 0x4e684b99
      Faulting module name: AcXtrnal.DLL, version: 6.1.7601.17571, time stamp: 0x4d708176
      Exception code: 0xc0000374
      Fault offset: 0x0000000000005b07
      Faulting process id: 0x1cf0
      Faulting application start time: 0x01cc79b152f672e7
      Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\Adobe Premiere Pro.exe
      Faulting module path: C:\Windows\AppPatch\AppPatch64\AcXtrnal.DLL
      Report Id: a4b34d55-e5a4-11e0-80b9-50e54935b2d5
      Occasionally it'll throw ntdll.dll instead of AcXtrnal.dll
      My system specs are as follows:
      Windows 7 64-bit Ultimate Edition SP1
      AMD Phenom 2 x4 945 3.0Ghz Quad-core processor
      8 Gigs Corsair Vengeance DDR3 RAM
      ATI Radeon HD 6850 video card, on Catalyst ver. 11.8
      Primary HDD: Western Digital Caviar Black 2 TB 7200 RPM SATA hard disk: 1.34 TB free
      Secondary HDD: Seagate Barricuda 1TB 7200 RPM SATA hard disk: 398 GB free
      I've scrounged the internet, testing everything I could find to see if it might be a solution, to no avail. I've adjusted compatibility settings, with no luck, ran as administrator, no luck either.
      Any help would be appreciated.
      Regards
      Message was edited by: VeriasX1
        • 1. Re: Premiere Pro CS5.5.1 Crashing on startup.
          Todd_Kopriva Level 8
          Try starting while holding Alt and Shift. This will reset all preferences and clear the plug-in cache.
          If that doesn't work, try uninstalling and then reinstalling.
          • 2. Re: Premiere Pro CS5.5.1 Crashing on startup.
            VeriasX1 Level 1
            alrighty. Initial test of alt and shift yielded no change, so I did a reinstall.
            Now, I can get into PPro -if- I'm holding alt+shift at the start, but if I'm not, it crashes on load.
            Once inside PPro, things I've noted are, preview/playback window isn't functioning. If I scrub or preview a video file, the video preview does not playback. I can "force" a single frame to "update" if I stop the playback and physically left-click the window. I can save and make changes to projects, but when I exit PPro, it crashes.
            At the time of crash, i'm getting two errors now
            The program Adobe Premiere Pro.exe version 5.5.1.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
            Process ID: 1cc0
            Start Time: 01cc7a2ae458c926
            Termination Time: 54
            Application Path: C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\Adobe Premiere Pro.exe
            Report Id: caab65ec-e61e-11e0-9093-50e54935b2d5
            and
            Schannel: Event ID 36888:
            The following fatal alert was generated: 10. The internal error state is 10.
            I guess this is kind of progress. I also appreciate the assist so far Todd.
            • 3. Re: Premiere Pro CS5.5.1 Crashing on startup.
              Hmmm. I think that getting any further might require having one of our Technical Support folks connect to your system for troubleshooting.
              To contact Adobe Technical Support, start here:
              http://www.adobe.com/support/contact
              Be sure to direct them to this thread so that they can see where you've gotten so far.
