5 Replies Latest reply on May 18, 2012 12:45 AM by APMABC
    InDesign Server complains of missing links after importing InDesign Tagged Text
    APMABC Newcomer
      Hi Folks,
      In my plug-ins for InDesign CS5/5.5 desktop I'm importing InDesign Tagged Text via the method IImportSuite::DoImport(). The code goes something like this...
          InterfacePtr<IImportSuite> ptrImportSuite(static_cast<IImportSuite *>(Utils<ISelectionUtils>()->QuerySuite(IImportSuite::kDefaultIID)));
          if (ptrImportSuite != nil)
              IDFile TaggedTextFile;
              if (CoreFileUtils::CreateUniqueTempFile( "My Tagged Text ", "", TaggedTextFile ))
                  if (WriteToFile( TaggedTextFile, TaggedText ))
                      URI ResourceID;
                      if (Utils<IURIUtils>()->IDFileToURI( TaggedTextFile, ResourceID ))
                          ptrImportSuite->DoImport( ResourceID,
                                                    DocumentReferenceID.GetDataBase(),
                                                    kTrue,
                                                    kMinimalUI,
                                                    kTrue,
                                                    kTrue,
                                                    kFalse );
                  TaggedTextFile.Delete();
      The tagged text is imported with no problems and is correctly formatted . I can save and reopen the document with no problems.
      Now if I open the same document via InDesign Server, I see this...
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877211421
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877212218
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877212984
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877213234
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877213406
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877213609
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877213875
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877222812
      09/23/11 13:40:04 ERROR [link manager] Link missing.; file:c:/TEMP/My%20Tagged%20Text%20480877238171
      The document has opened and I can edit the imported text - so it would appear that the text is embedded in the document. But InDesign Server is complaining that links to the text files are missing. Which should it be - no embedded text with linked files or embedded text and no linked files? What I'm after is embedded text with no linked files as the files are temporary and only a means to an end.
      If I open the document in the Desktop application, the Links tab is not showing any links, which is what I'd expect. So what's up with Server? I should also note that in Preferences\File Handling\Links "Create Links When Placing Text and Spreadsheet Files" is using the default setting - unchecked.
      Any insight on this would be appreciated.
      Regards,
      Andrew
      PS - I'm on holiday next week!
