4 Replies Latest reply on Oct 4, 2011 4:57 PM by Michael J Roberts
    How to set header background color in a spark datagrid
    dsNYC76
      I have searched high and low for an answer to what should be a simple question.  I want to change the background color of only the column header area of my datagrid.  I think it has to be done in a custom skin which I've created but I can't figure out what to do next. I have created custom button and panel skins and changed background colors with no problem.
      Any assistance would be gretly apreicated.
        • 1. Re: How to set header background color in a spark datagrid
          Michael J Roberts Level 2
          Hi,  I beleive you'll want to create a custom DataGridSkin and change the HeaderRenderer to a custom GridItemRenderer.  To do this the dataGrid definition could look something like this:
          <s:DataGrid skinClass="RedDataGridSkin">
          RedDataGridSkin could look something like this:
          <spark:DataGridSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
                              xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:spark="spark.skins.spark.*"
                              xmlns:local="*">
              <fx:Declarations>
                  <fx:Component id="headerRenderer">
                      <local:RedGridHeaderRenderer />
                  </fx:Component>
              </fx:Declarations>
          </spark:DataGridSkin>
          And the RedGridHeaderRenderer can be almost a carbon copy of the SDKs DefaultGridHeaderRenderer, but just changing around some of the colors or adding in some skinning assets.
          I will add a more complete answer as a follow up comment and will soon post the full solution with a working example on ramblingdeveloper.com.
          -Mike
          • 2. Re: How to set header background color in a spark datagrid
            I have posted a full solution and a demo with example code on ramblingdeveloper.com.
            The direct link to the article is HERE.
            The link to the demo and source is HERE.
            I hope this helps you with your problem.
            -Mike
            • 3. Re: How to set header background color in a spark datagrid
              dsNYC76 Level 1
              Sorry for the long delay in responding.   Thanks for the posts and the detailed samples. Your solution was fairly easy and did the trick.  I wish I understood why Adobe makes it so complicated to do basic styling tasks.
              Now that I have the header background color set (solid  dark blue), how can I set the color of the header text?
              • 4. Re: How to set header background color in a spark datagrid
                Within your "BlueGridHeaderRenderer" mxml, simply add a script block that looks like this:
                <fx:Script>
                        <![CDATA[
                            override public function prepare(hasBeenRecycled:Boolean):void{
                                super.prepare(hasBeenRecycled);
                                labelDisplay.setStyle("color",0xFF0000);
                    </fx:Script>
                Just change the hex color code in the setStyle call to be whatever color you want.
