6 Replies Latest reply on Oct 11, 2011 2:40 PM by ed_skinner
    Class changes not being compiled into swf
    ed_skinner
      Hi Everyone,
          I have seen iterations of this issue but not the exact issue I am struggling with now.  I am currently using FlashBuilder 4.5.1 and have a project that is compiled in sdk 3.5.  I have included sdk 3.5 into FB 4.5.1 and everything seems to work with the exception of the design view which is another issue entirely.  I have a class that is instantiated from the mxml file that in turn instantiates a bean.  This bean is a container bean for a number of other beans and when everything is compiled and working it works well.  The major problem is when I make a change to the core bean or end bean the changes are not reflected in the compiled swf.  For example if I add a variable to the bean class and then try to reference the variable through the object instantiation, it states that the variable does not exist.  Now if I rename the class it works perfectly.  I have tried all the obvious, clear browser cache, clean project.  I even went in and manually deleted the cached filed in the metadata directories for FB and I just can not get it to see the changes to the bean.  This will happen on any core or end bean that I make changes to.
           I have tried FB 4.5 and the exact same issue occurs.  I have tried to compile using SDK 3.6 as well no help.
           This is a severe problem as these beans are used throughout the application and I just can not keep renaming the beans because they are everywhere.
          Any thoughts on why and where this is happening?  I used FlexBuilder and this wasn't an issue but now this is just stopping me in my tracks.
      Thanks in advance for your assistance,
      Ed
        • 1. Re: Class changes not being compiled into swf
          ed_skinner Level 1
          Hi All,
              No one has any thoughts as to why this is happening?  I am still stuck on this issue with a deadline looming .  This is a real problem and I am wondering if other folks are seeing this issue as well.  Does anyone else use container classes with success under this configuration?  Any assistance would be greatly appreciated!
          Thanks in advance,
          Ed
          • 2. Re: Class changes not being compiled into swf
            ed_skinner Level 1
            Hi All,
                  Perhaps I need to be a bit clearer as to what I am doing?  My appologies if I was not.
            The core or end class looks like so:
            package com.beans
                 [Bindable]
                 public class InnerBean
                       public var MyID:Number = 0;
                 public function InnerBean()
            The container class looks like so:
            package com.beans
                 [Bindable]
                 public class ContainerBean
                      public var MyInnerBean:InnerBean = new InnerBean();
                 public function ContainerBean()
            Then I instantiate the container bean in a MXML file throught the script tag as such
            import com.beans.ContainerBean;
            [Bindable] MyContainerBean:ContainerBean = new ContainerBean();
            Simple enough right... Except with I add a variable to the Inner bean... It compiles, FB's tag follow sees the variable but when the runtime tries to access it, the runtime complains stating it doesn't exist...   If I rename the inner bean to a different name it works perfectly....
            Hope this brings clarity and someone can help me identify what exactly is going on.
            Thanks again in advance!
            Ed
            • 3. Re: Class changes not being compiled into swf
              Anirudh Sasikumar Adobe Employee
              Thanks for the sample, I'm trying it out right now to see what is actually going on under the hood.
              -Anirudh
              • 4. Re: Class changes not being compiled into swf
                I tried it out, seems to work. The minute I add a field to InnerBean, the last modified time and size of SWF changes.
                That means there must be something else needed to repro the issue.
                I've attached the project I created to test this at http://anirudhsasikumar.net/examples/CompilerTest.fxp
                Can you try that out and modify it till you run into the problem you described?
                -Anirudh
                • 5. Re: Class changes not being compiled into swf
                  Your Flash Builder log file at workspacedir/.metadata/.log might be useful. Copy paste the contents of that log file here.
                  -Anirudh
                  • 6. Re: Class changes not being compiled into swf
                    ed_skinner Level 1
                         Thank you so much for your reply!   I will include the .log file excerpts for today at the end of this post.  I did try your project and it worked fine for me as well, however, there is still something very strange going on here.  The scenario I have is a bit more complex I believe.  I am using the FlexMDI project to call the modules that render the classes.  The end classes are instanciated from actioncript classes that are then instanciated from MXML files that are instanciated from the original module files.  The original module file is a combination of MXML files and included actionscript files with the intent to segregate the as code from the mxml code.  This all works on another developers machine with no problem but when it comes to my machine it does not.  I have reinstalled, tried three different Flex,Flash builders to no avail.  I am obviously missing something but can not put my finger on it and it is driving my nuts.
                    I have also included a screen shot of a debug session that shows the class with an new variable that is clearly included in the class as well as an parent class that this class inherits and the Variables window that shows neither.  How can the debug session show these items but the Variables window not?  Very strange....
                    Any thoughts on this issue I would be eternally gratefull!!!
                    Ed
                    Log File:
                    !SESSION 2011-10-11 10:19:08.160 -----------------------------------------------
                    eclipse.buildId=unknown
                    java.version=1.6.0_16
                    java.vendor=Sun Microsystems Inc.
                    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
                    Command-line arguments:  -os win32 -ws win32 -arch x86
                    !ENTRY org.eclipse.jface 2 0 2011-10-11 10:19:21.958
                    !MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
                    !SUBENTRY 1 org.eclipse.jface 2 0 2011-10-11 10:19:21.958
                    !MESSAGE A conflict occurred for CTRL+SHIFT+C:
                    Binding(CTRL+SHIFT+C,
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.AutoComment,Insert Auto Comment,
                      Insert a comment based on section.,
                      Category(org.cfeclipse.cfml.commandCategory,CFML Editor,CFML Editor key bindings,true),
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.AutoCommentAction),
                      ,,true),null),
                    org.eclipse.ui.defaultAcceleratorConfiguration,
                    org.cfeclipse.cfml.cfmleditorcontext,,,system)
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.InsertColor,Insert Color,
                      Insert a color,
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.InsertColorAction),
                      ,,true),null),
                    !ENTRY org.eclipse.jface 2 0 2011-10-11 10:19:40.939
                    !SUBENTRY 1 org.eclipse.jface 2 0 2011-10-11 10:19:40.939
                    !MESSAGE A conflict occurred for CTRL+I:
                    Binding(CTRL+I,
                    ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.organize.autoindent,Correct Indentation,
                      Category(com.adobe.flexbuilder.as.editor.source.editing.category,ActionScript Source Editing,null,true),
                      ,,true),null),
                    com.adobe.flexide.editorcore.flexEditorScope,,,system)
                    Binding(CTRL+I,
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.EmTag,Insert em Tag,
                      Insert an em tag,
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.EmTagAction),
                      ,,true),null),
                    !MESSAGE A conflict occurred for CTRL+SHIFT+D:
                    Binding(CTRL+SHIFT+D,
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.CFDump,CF Dump,
                      Surround with a simple cfdump,
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.CFDumpAction),
                      ,,true),null),
                    ParameterizedCommand(Command(com.adobe.flexide.editorcore.add.other.comment,Add Other Comment,
                      Category(com.adobe.flexbuilder.editorcore.flex.edit,Flex Editing,null,true),
                      ,,true),null),
                    !MESSAGE A conflict occurred for CTRL+SHIFT+P:
                    Binding(CTRL+SHIFT+P,
                    ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.go.to.brace,Go to Matching Bracket,
                      Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true),
                      ,,true),null),
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.PTag,Insert p Tag,
                      Insert a p tag,
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.PTagAction),
                      ,,true),null),
                    !MESSAGE A conflict occurred for CTRL+SHIFT+M:
                    Binding(CTRL+SHIFT+M,
                    ParameterizedCommand(Command(com.adobe.flexbuilder.mxml.editor.ToggleStateCommand,Toggle &State Visualization,
                      Category(com.adobe.flexbuilder.mxml.editor.stateNav,MXML State Visualization,null,true),
                      ,,true),null),
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.CFComment,Insert Comment,
                      Insert a CFML comment.,
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.CFCommentAction),
                      ,,true),null),
                    !MESSAGE A conflict occurred for ALT+CTRL+R:
                    Binding(ALT+CTRL+R,
                    ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.rename.element,Rename,
                      ,,true),null),
                    Binding(ALT+CTRL+R,
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.CFScript,CF Script,
                      Surround with a cfscript,
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.CFScriptAction),
                      ,,true),null),
                    !MESSAGE A conflict occurred for CTRL+SHIFT+O:
                    Binding(CTRL+SHIFT+O,
                    ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.organize.imports,Organize Imports,
                      ,,true),null),
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.CFOutput,CF Outputs,
                      Surround with cfoutputs,
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.CFOutputAction),
                      ,,true),null),
                    !MESSAGE A conflict occurred for CTRL+G:
                    Binding(CTRL+G,
                    ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.wor kspace,Find All Declarations In Workspace,
                      ,,true),null),
                    Binding(CTRL+G,
                    ParameterizedCommand(Command(org.cfeclipse.cfml.editors.actions.GotoFileAction,Open Linked file,
                      Open Linked file,
                      ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.editors.actions.GotoFileAction),
                      ,,true),null),
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:33.146
                    !MESSAGE Unhandled event loop exception
                    !STACK 0
                    java.lang.NullPointerException
                    at org.eclipse.jface.text.AbstractDocument.getOffset(AbstractDocument.java:525)
                    at org.eclipse.jface.text.AbstractDocument.computeIndexInPositionList(AbstractDocument.java: 500)
                    at org.eclipse.jface.text.AbstractDocument.getEndingPositions(AbstractDocument.java:1794)
                    at org.eclipse.jface.text.AbstractDocument.getPositions(AbstractDocument.java:1704)
                    at org.eclipse.jface.text.source.AnnotationModel.getRegionAnnotationIterator(AnnotationModel .java:737)
                    at org.eclipse.jface.text.source.AnnotationModel.getAnnotationIterator(AnnotationModel.java: 699)
                    at org.eclipse.jface.text.source.AnnotationRulerColumn.doPaint1(AnnotationRulerColumn.java:7 18)
                    at org.eclipse.jface.text.source.AnnotationRulerColumn.doubleBufferPaint(AnnotationRulerColu mn.java:532)
                    at org.eclipse.jface.text.source.AnnotationRulerColumn.redraw(AnnotationRulerColumn.java:811 )
                    at org.eclipse.jface.text.source.AnnotationRulerColumn$InternalListener.viewportChanged(Anno tationRulerColumn.java:77)
                    at org.eclipse.jface.text.TextViewer.updateViewportListeners(TextViewer.java:3097)
                    at org.eclipse.jface.text.TextViewer.internalRevealRange(TextViewer.java:3269)
                    at org.eclipse.jface.text.TextViewer.revealRange(TextViewer.java:3226)
                    at org.eclipse.jface.text.source.projection.ProjectionViewer.findAndSelect(ProjectionViewer. java:1762)
                    at org.eclipse.jface.text.TextViewer$FindReplaceTarget.findAndSelect(TextViewer.java:879)
                    at org.eclipse.ui.texteditor.FindReplaceTarget.findAndSelect(FindReplaceTarget.java:88)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.findAndSelect(FindReplaceDialog.java:812)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.findIndex(FindReplaceDialog.java:772)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.findNext(FindReplaceDialog.java:871)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.performSearch(FindReplaceDialog.java:1361)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.performSearch(FindReplaceDialog.java:1340)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.access$25(FindReplaceDialog.java:1339)
                    at org.eclipse.ui.texteditor.FindReplaceDialog$1.widgetSelected(FindReplaceDialog.java:313)
                    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
                    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
                    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
                    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
                    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
                    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
                    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
                    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
                    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
                    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                    at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :109)
                    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
                    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
                    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                    at java.lang.reflect.Method.invoke(Unknown Source)
                    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
                    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
                    at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:33.177
                    !STACK 0
                    org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
                    at org.eclipse.swt.SWT.error(SWT.java:3884)
                    at org.eclipse.swt.SWT.error(SWT.java:3799)
                    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
                    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
                    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
                    Caused by: java.lang.NullPointerException
                    at org.eclipse.jface.text.source.AnnotationRulerColumn$6.run(AnnotationRulerColumn.java:798)
                    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
                    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:33.181
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:33.184
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:33.187
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:33.189
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:33.192
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:33.196
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:35.183
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:35.212
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:35.216
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:35.220
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:36.447
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:36.476
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:36.481
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:36.485
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:37.168
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:37.196
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:37.201
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:37.207
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:40.489
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:40.516
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:40.526
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:40.532
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.036
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.059
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.066
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.378
                    !STACK 0
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.391
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.395
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.399
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.402
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.405
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:41.408
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:48.351
                    !STACK 0
                    at org.eclipse.jface.text.TextViewer$ViewportGuard.widgetSelected(TextViewer.java:332)
                    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
                    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
                    at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:770)
                    at org.eclipse.swt.custom.StyledText.sendSelectionEvent(StyledText.java:7482)
                    at org.eclipse.swt.custom.StyledText.doSelection(StyledText.java:3201)
                    at org.eclipse.swt.custom.StyledText.doPageDown(StyledText.java:2894)
                    at org.eclipse.swt.custom.StyledText.doSelectionPageDown(StyledText.java:3296)
                    at org.eclipse.swt.custom.StyledText$3.run(StyledText.java:2172)
                    at org.eclipse.swt.widgets.Display.runTimer(Display.java:3943)
                    at org.eclipse.swt.widgets.Display.messageProc(Display.java:3135)
                    at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
                    at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2410)
                    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3471)
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:48.785
                    !STACK 0
                    at org.eclipse.jface.text.TextViewer$ViewportGuard.mouseUp(TextViewer.java:314)
                    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:207)
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:48.867
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:48.874
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:48.879
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.core.resources 4 2 2011-10-11 11:38:50.782
                    !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
                    !STACK 0
                    at org.eclipse.jface.text.AbstractDocument.addPosition(AbstractDocument.java:366)
                    at org.cfeclipse.cfml.editors.ICFDocument.addPosition(ICFDocument.java:169)
                    at org.eclipse.jface.text.AbstractDocument.addPosition(AbstractDocument.java:374)
                    at org.eclipse.jface.text.source.AnnotationModel.addPosition(AnnotationModel.java:477)
                    at org.eclipse.jface.text.source.AnnotationModel.addAnnotation(AnnotationModel.java:439)
                    at org.eclipse.ui.texteditor.AbstractMarkerAnnotationModel.addMarkerAnnotation(AbstractMarke rAnnotationModel.java:228)
                    at org.eclipse.ui.texteditor.ResourceMarkerAnnotationModel.update(ResourceMarkerAnnotationMo del.java:102)
                    at org.eclipse.ui.texteditor.ResourceMarkerAnnotationModel$ResourceChangeListener.resourceCh anged(ResourceMarkerAnnotationModel.java:56)
                    at org.eclipse.core.internal.events.NotificationManager$2.run(NotificationManager.java:291)
                    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
                    at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
                    at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager .java:149)
                    at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:313)
                    at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1022)
                    at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1809)
                    at org.eclipse.ui.texteditor.MarkerUtilities.createMarker(MarkerUtilities.java:399)
                    at org.cfeclipse.cfml.editors.dnd.SelectionCursorListener.markBeginEndTags(SelectionCursorLi stener.java:663)
                    at org.cfeclipse.cfml.editors.dnd.SelectionCursorListener.setSelectedTag(SelectionCursorList ener.java:264)
                    at org.cfeclipse.cfml.editors.dnd.SelectionCursorListener.selectionChanged(SelectionCursorLi stener.java:384)
                    at org.eclipse.jface.text.TextViewer.firePostSelectionChanged(TextViewer.java:2731)
                    at org.eclipse.jface.text.TextViewer.firePostSelectionChanged(TextViewer.java:2679)
                    at org.eclipse.jface.text.TextViewer$5.run(TextViewer.java:2658)
                    !ENTRY org.eclipse.core.resources 4 2 2011-10-11 11:38:50.787
                    !STACK 0
                    at org.cfeclipse.cfml.editors.dnd.SelectionCursorListener.markBeginEndTags(SelectionCursorLi stener.java:664)
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:59.728
                    !MESSAGE An unexpected exception was thrown.
                    !STACK 0
                    at org.eclipse.jface.text.AbstractDocument.removeFromPositionsList(AbstractDocument.java:105 8)
                    at org.eclipse.jface.text.AbstractDocument.removePosition(AbstractDocument.java:1043)
                    at org.cfeclipse.cfml.editors.ICFDocument.removePosition(ICFDocument.java:178)
                    at org.eclipse.jface.text.AbstractDocument.removePosition(AbstractDocument.java:1090)
                    at org.eclipse.jface.text.source.AnnotationModel.removePosition(AnnotationModel.java:491)
                    at org.eclipse.jface.text.source.AnnotationModel.disconnect(AnnotationModel.java:558)
                    at org.eclipse.jface.text.source.AnnotationModel.disconnect(AnnotationModel.java:546)
                    at org.eclipse.jface.text.source.SourceViewer.disposeVisualAnnotationModel(SourceViewer.java :524)
                    at org.eclipse.jface.text.source.SourceViewer.handleDispose(SourceViewer.java:669)
                    at org.eclipse.jface.text.source.projection.ProjectionViewer.handleDispose(ProjectionViewer. java:1362)
                    at org.eclipse.jface.text.TextViewer$2.widgetDisposed(TextViewer.java:1788)
                    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:117)
                    at org.eclipse.swt.custom.StyledText.handleDispose(StyledText.java:5712)
                    at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.java:5540)
                    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
                    at org.eclipse.swt.widgets.Widget.release(Widget.java:804)
                    at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:756)
                    at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:174)
                    at org.eclipse.swt.widgets.Widget.release(Widget.java:807)
                    at org.eclipse.swt.widgets.Widget.dispose(Widget.java:441)
                    at org.eclipse.ui.internal.PartPane.dispose(PartPane.java:180)
                    at org.eclipse.ui.internal.WorkbenchPartReference.dispose(WorkbenchPartReference.java:681)
                    at org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchPage.java:1715)
                    at org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(WorkbenchPage.java:1422)
                    at org.eclipse.ui.internal.WorkbenchPage.deferUpdates(WorkbenchPage.java:1406)
                    at org.eclipse.ui.internal.WorkbenchPage.closeEditors(WorkbenchPage.java:1380)
                    at org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchPage.java:1435)
                    at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:61)
                    at org.eclipse.ui.internal.PartStack.close(PartStack.java:543)
                    at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:206)
                    at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:122)
                    at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation$1.handleEvent(TabbedSt ackPresentation.java:83)
                    at org.eclipse.ui.internal.presentations.util.AbstractTabFolder.fireEvent(AbstractTabFolder. java:270)
                    at org.eclipse.ui.internal.presentations.util.AbstractTabFolder.fireEvent(AbstractTabFolder. java:279)
                    at org.eclipse.ui.internal.presentations.defaultpresentation.DefaultTabFolder.access$1(Defau ltTabFolder.java:1)
                    at org.eclipse.ui.internal.presentations.defaultpresentation.DefaultTabFolder$1.closeButtonP ressed(DefaultTabFolder.java:70)
                    at org.eclipse.ui.internal.presentations.PaneFolder.notifyCloseListeners(PaneFolder.java:626 )
                    at org.eclipse.ui.internal.presentations.PaneFolder$3.close(PaneFolder.java:206)
                    at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:2199)
                    at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:327)
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:59.759
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:59.764
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:59.771
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:38:59.774
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:49:28.893
                    !STACK 0
                    at org.eclipse.jface.text.DefaultPositionUpdater.update(DefaultPositionUpdater.java:233)
                    at org.eclipse.jface.text.AbstractDocument.updatePositions(AbstractDocument.java:1219)
                    at org.eclipse.jface.text.AbstractDocument.updateDocumentStructures(AbstractDocument.java:68 3)
                    at org.eclipse.jface.text.AbstractDocument.fireDocumentChanged(AbstractDocument.java:759)
                    at org.eclipse.jface.text.AbstractDocument.replace(AbstractDocument.java:1157)
                    at org.eclipse.jface.text.AbstractDocument.replace(AbstractDocument.java:1176)
                    at org.eclipse.jface.text.FindReplaceDocumentAdapter.findReplace(FindReplaceDocumentAdapter. java:213)
                    at org.eclipse.jface.text.FindReplaceDocumentAdapter.replace(FindReplaceDocumentAdapter.java :604)
                    at org.eclipse.jface.text.TextViewer$FindReplaceTarget.replaceSelection(TextViewer.java:829)
                    at org.eclipse.ui.texteditor.FindReplaceTarget.replaceSelection(FindReplaceTarget.java:141)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.replaceSelection(FindReplaceDialog.java:832)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.performReplaceSelection(FindReplaceDialog.jav a:1322)
                    at org.eclipse.ui.texteditor.FindReplaceDialog.access$28(FindReplaceDialog.java:1311)
                    at org.eclipse.ui.texteditor.FindReplaceDialog$2.widgetSelected(FindReplaceDialog.java:324)
                    !ENTRY org.eclipse.core.resources 4 2 2011-10-11 11:49:39.045
                    !STACK 0
                    at org.eclipse.jface.text.AbstractDocument.getOffset(AbstractDocument.java:526)
                    at org.eclipse.jface.text.AbstractDocument.removePosition(AbstractDocument.java:1038)
                    at org.eclipse.jface.text.source.AnnotationModel.removeAnnotation(AnnotationModel.java:856)
                    at org.eclipse.ui.texteditor.AbstractMarkerAnnotationModel.removeMarkerAnnotation(AbstractMa rkerAnnotationModel.java:385)
                    at org.eclipse.ui.texteditor.ResourceMarkerAnnotationModel.update(ResourceMarkerAnnotationMo del.java:105)
                    at org.eclipse.core.internal.resources.Marker.delete(Marker.java:70)
                    at org.cfeclipse.cfml.editors.dnd.SelectionCursorListener.clearTagBeginEndMarkers(SelectionC ursorListener.java:683)
                    at org.cfeclipse.cfml.editors.dnd.SelectionCursorListener.setSelectedTag(SelectionCursorList ener.java:251)
                    !ENTRY org.eclipse.core.resources 4 2 2011-10-11 11:49:40.995
                    !STACK 0
                    at org.eclipse.jface.text.AbstractDocument.computeIndexInPositionList(AbstractDocument.java: 453)
                    at org.eclipse.jface.text.AbstractDocument.addPosition(AbstractDocument.java:361)
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:49:43.610
                    !STACK 0
                    org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalStateException)
                    Caused by: java.lang.IllegalStateException
                    at org.eclipse.jface.text.projection.ProjectionMapping.toImageLine(ProjectionMapping.java:48 0)
                    at org.eclipse.jface.text.TextViewer.modelLine2WidgetLine(TextViewer.java:5237)
                    at org.eclipse.jface.text.JFaceTextUtil.modelLineToWidgetLine(JFaceTextUtil.java:224)
                    at org.eclipse.jface.internal.text.source.DiffPainter.paintLine(DiffPainter.java:220)
                    at org.eclipse.jface.internal.text.source.DiffPainter.paint(DiffPainter.java:158)
                    at org.eclipse.jface.text.source.LineNumberChangeRulerColumn.doPaint(LineNumberChangeRulerCo lumn.java:190)
                    at org.eclipse.jface.text.source.LineNumberRulerColumn.doubleBufferPaint(LineNumberRulerColu mn.java:692)
                    at org.eclipse.jface.text.source.LineNumberRulerColumn.redraw(LineNumberRulerColumn.java:844 )
                    at org.eclipse.jface.text.source.LineNumberRulerColumn$1.run(LineNumberRulerColumn.java:411)
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:49:44.119
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:49:49.077
                    !STACK 0
                    org.eclipse.core.runtime.AssertionFailedException: assertion failed:
                    at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
                    at org.eclipse.core.runtime.Assert.isTrue(Assert.java:96)
                    at org.eclipse.ui.internal.texteditor.quickdiff.DocumentLineDiffer.handleAboutToBeChanged(Do cumentLineDiffer.java:794)
                    at org.eclipse.ui.internal.texteditor.quickdiff.DocumentLineDiffer.documentAboutToBeChanged( DocumentLineDiffer.java:763)
                    at org.eclipse.jface.text.AbstractDocument.fireDocumentAboutToBeChanged(AbstractDocument.jav a:645)
                    at org.eclipse.jface.text.AbstractDocument.replace(AbstractDocument.java:1148)
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:49:57.565
                    !STACK 0
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:50:03.036
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.core.resources 4 2 2011-10-11 11:50:06.906
                    !STACK 0
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:50:09.126
                    !STACK 0
                    ... 22 more
                    !ENTRY org.eclipse.ui 4 0 2011-10-11 11:50:14.269
                    !STACK 0
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:28.477
                    !MESSAGE Problems occurred refreshing resources
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:28.477
                    !MESSAGE Problem occurred in auto-refresh native code: 5.
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:29.529
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:29.529
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:30.579
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:30.579
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:31.632
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:31.632
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:32.703
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:32.703
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:33.756
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:33.756
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:34.806
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:34.806
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:35.858
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:35.858
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:36.908
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:36.908
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:37.962
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:37.962
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:38.963
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:38.963
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:40.023
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:40.023
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:41.074
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:41.074
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:42.128
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:42.128
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:43.178
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:43.178
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:44.229
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:44.229
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:45.282
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:45.282
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:46.302
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:46.302
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:47.339
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:47.339
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:48.389
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:48.389
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:49.442
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:49.442
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:50.493
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:50.493
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:51.546
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:51.546
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:52.596
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:52.596
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:53.649
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:53.649
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:54.700
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:54.700
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:55.753
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:55.753
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:56.755
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:56.755
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:57.808
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:57.808
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:58.858
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:58.858
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:23:59.911
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:23:59.911
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:00.962
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:00.962
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:02.448
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:02.448
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:03.501
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:03.501
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:04.552
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:04.552
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:05.605
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:05.605
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:06.655
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:06.655
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:07.708
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:07.708
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:08.737
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:08.737
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:09.788
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:09.788
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:10.839
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:10.839
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:11.896
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:11.896
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:12.946
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:12.946
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:14.009
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:14.009
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:15.013
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:15.013
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:16.664
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:16.664
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:17.716
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:17.716
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:18.763
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:18.763
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:19.814
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:19.814
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:20.838
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:20.838
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:21.891
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:21.891
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:22.945
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:22.945
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:23.997
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:23.998
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:25.048
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:25.048
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:26.100
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:26.100
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:27.150
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:27.150
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:28.202
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:28.202
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:29.254
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:29.254
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:30.304
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:30.304
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:31.308
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:31.308
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:32.359
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:32.359
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:33.412
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:33.412
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:34.462
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:34.462
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:35.515
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:35.515
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:36.565
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:36.565
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:37.616
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:37.616
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:38.666
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:38.666
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:39.718
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:39.718
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:40.769
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:40.769
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:41.822
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:41.822
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:42.826
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:42.826
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:43.879
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:43.879
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:44.933
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:44.933
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:45.985
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:45.985
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:47.038
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:47.038
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:48.091
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:48.092
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:49.143
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:49.144
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:50.158
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:50.158
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:51.161
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:51.161
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:52.211
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:52.211
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:53.264
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:53.265
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:54.315
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:54.315
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:55.368
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:55.368
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:56.379
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:56.379
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:57.431
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:57.431
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:58.482
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:58.482
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:24:59.509
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:24:59.509
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:25:00.546
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:25:00.546
                    !ENTRY org.eclipse.core.resources 4 1 2011-10-11 12:25:01.608
                    !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-10-11 12:25:01.608
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 16:54:41.162
                    !MESSAGE Error getting list of source files
                    !STACK 0
                    flash.tools.debugger.InProgressException
                    at flash.tools.debugger.concrete.DSwfInfo.swdLoaded(DSwfInfo.java:153)
                    at flash.tools.debugger.concrete.DSwfInfo.getSourceList(DSwfInfo.java:129)
                    at flash.tools.debugger.threadsafe.ThreadSafeSwfInfo.getSourceList(ThreadSafeSwfInfo.java:78 )
                    at com.adobe.flexbuilder.debug.breakpoints.FlexLineBreakpoint.findSourceFiles(FlexLineBreakp oint.java:412)
                    at com.adobe.flexbuilder.debug.breakpoints.FlexLineBreakpoint.instantiate(FlexLineBreakpoint .java:465)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget.instantiateBreakpoint(FlexDebugTarget.j ava:1012)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget.access$4(FlexDebugTarget.java:1006)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.installDeferredBreakpoints(Fl exDebugTarget.java:637)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.advanceStateMachine(FlexDebug Target.java:668)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.access$7(FlexDebugTarget.java :642)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread$1.run(FlexDebugTarget.java:75 2)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.eventLoop(FlexDebugTarget.jav a:732)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.run(FlexDebugTarget.java:793)
                    at java.lang.Thread.run(Unknown Source)
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 16:54:41.233
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 16:57:10.807
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 16:57:10.864
                    !STACK 0
                    !ENTRY CodeModel 4 1 2011-10-11 16:57:48.994
                    !MESSAGE Project data is stale for comment ref: AdminUserAccounts
                    !STACK 0
                    java.lang.Exception
                    at com.adobe.flexbuilder.codemodel.internal.asdoc.ClassCommentRef.<init>(ClassCommentRef.jav a:40)
                    at com.adobe.flexbuilder.codemodel.internal.tree.ClassNode.getDynamicCommentRef(ClassNode.ja va:797)
                    at com.adobe.flexbuilder.codemodel.internal.tree.BaseDefinitionNode.getComment(BaseDefinitio nNode.java:354)
                    at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProposal.<init>(ActionScrip tCompletionProposal.java:164)
                    at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProcessor.getTypeProposal(A ctionScriptCompletionProcessor.java:693)
                    at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProcessor.createProposalsFr omDefinitions(ActionScriptCompletionProcessor.java:1009)
                    at com.adobe.flexide.as.core.contentassist.ActionScriptCompletionProcessor.computeCompletion Proposals(ActionScriptCompletionProcessor.java:1307)
                    at org.eclipse.jface.text.contentassist.ContentAssistant.computeCompletionProposals(ContentA ssistant.java:1832)
                    at org.eclipse.jface.text.contentassist.CompletionProposalPopup.computeProposals(CompletionP roposalPopup.java:556)
                    at org.eclipse.jface.text.contentassist.CompletionProposalPopup.access$16(CompletionProposal Popup.java:553)
                    at org.eclipse.jface.text.contentassist.CompletionProposalPopup$2.run(CompletionProposalPopu p.java:488)
                    at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
                    at org.eclipse.jface.text.contentassist.CompletionProposalPopup.showProposals(CompletionProp osalPopup.java:482)
                    at org.eclipse.jface.text.contentassist.ContentAssistant$2.run(ContentAssistant.java:376)
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 16:58:15.234
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 16:58:15.292
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:06:52.597
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:06:52.655
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:09:03.556
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:09:03.615
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:13:07.929
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:13:08.011
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:13:31.523
                    !STACK 0
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$1.run(FlexDebugTarget.java:1054)
                    at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:14:20.005
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:14:20.012
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:14:20.096
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:14:20.107
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:16:30.166
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:16:30.173
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:16:30.229
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:16:30.237
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:17:28.551
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:17:28.558
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:17:28.616
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-10-11 17:17:28.625
                    !STACK 0
