27 Replies Latest reply on Oct 11, 2011 9:37 PM by kglad
    my flash reads the xml, but does not understand the tag php....
    armandix Level 1
      my flash reads the xml, but does not understand the tag php. I want to read my xml dynamically, please help me.
      code:
      stop();
      function randomOrder(targetArray)
          var _loc2 = targetArray.length;
          var _loc3 = [];
          for (var _loc1 = 0; _loc1 < _loc2; ++_loc1)
              _loc3[_loc1] = _loc1;
          } // end of for
          var _loc4 = [];
              _loc4[_loc1] = _loc3.splice(Math.floor(Math.random() * _loc3.length), 1);
          } // end of for
          var _loc5 = [];
              _loc5[_loc1] = targetArray[_loc4[_loc1]];
          } // end of for
          return (_loc5);
      } // End of the function
      var randomNUM = "?n=" + random(9999);
      _root.lan = 1;
      var homehead;
      var homelink;
      var homelinkwindow;
      var homebg;
      var homeflash;
      var lamp = Array();
      var promo = Array();
      var promobottom = Array();
      var headimg = Array();
      f_xmlwork2 = new XML();
      f_xmlwork2.ignoreWhite=true;
      f_xmlwork2.load("banner.php");
      f_xmlwork2.onLoad = function(sucess){
          if (sucess){
               trace ("XML loaded!");
               f_xmlItemx2 = parseInt(this.firstChild.childNodes[0].firstChild);
               f_totalx2 = f_xmlItemx2.length;
              trace(f_totalx2);
               var _loc12 =0;
               // declarar a imagem de fundo
               homebg = this.firstChild.childNodes[0].firstChild.nodeValue;
               f_headimg = this.childNodes[1];
                   for (var _loc2 = 0; _loc2 < f_headimg.childNodes.length; ++_loc2)    {
      juju = f_headimg.childNodes[_loc2];
      jj = headimg.push({headimg: f_headimg.childNodes[_loc2].attributes.headimg, bgimg: f_headimg.childNodes[_loc2].attributes.bgimg, msgimg: f_headimg.childNodes[_loc2].attributes.msgimg, leftthrow: f_headimg.childNodes[_loc2].attributes.leftthrow, rightthrow: f_headimg.childNodes[_loc2].attributes.rightthrow});
                   //end for
      allpromo = this.childNodes[2];
      jjpromo = allpromo.childNodes;
      for (var _loc2 = 0; _loc2 < allpromo.childNodes.length; ++_loc2)
      trace (jjpromo[_loc2].attributes.title);
      jj = promo.push({img: jjpromo[_loc2].attributes.img, title: jjpromo[_loc2].attributes.title, url: jjpromo[_loc2].attributes.url, window: jjpromo[_loc2].attributes.window, info: jjpromo[_loc2].childNodes[0].nodeValue});
          // end of for
          allpromobottom = this.childNodes[3];
          jjpromobottom = allpromobottom.childNodes;
          for (var _loc2 = 0; _loc2 < allpromobottom.childNodes.length; ++_loc2)
              jj = promobottom.push({url: jjpromobottom[_loc2].attributes.url, window: jjpromobottom[_loc2].attributes.window, info: jjpromobottom[_loc2].childNodes[0].nodeValue});
          } // end of for
           if (f_xmlwork2.loaded == true)
              headimg = randomOrder(headimg);
                  trace (headimg[_loc2].headimg);
              } // end of for
              play ();
          } // end if
      trace(f_xmlwork2);
      stop();
      PHP code:
      $link=  mysql_connect("localhost","rnpac_eco","123");
      mysql_select_db("rnpac");
      $dir="banner/";
      $dir1="produtos/img_pro/";
      $dir2="universo/actividades/";
      $sql = 'SELECT tbl_produto.id_produto, tbl_produto.produto, tbl_produto.legenda, tbl_produto.detalhe, tbl_produto.preco, tbl_produto.produto_cat_id, tbl_detalhe_produto.proprietario, tbl_detalhe_produto.local, tbl_detalhe_produto.qualidade, tbl_detalhe_produto.alcool, tbl_detalhe_produto.acidez, tbl_detalhe_produto.ph, tbl_detalhe_produto.informacao, tbl_detalhe_produto.gestor, tbl_detalhe_produto.condicionamento, tbl_detalhe_produto.detalhe_t, tbl_detalhe_produto.interesse, tbl_detalhe_produto.transporte, tbl_detalhe_produto.produto_id, tbl_imagem_produto.id_imagem, tbl_imagem_produto.imagem1, tbl_imagem_produto.imagem2, tbl_imagem_produto.imagem3, tbl_imagem_produto.imagem4, tbl_imagem_produto.imagem5, tbl_imagem_produto.imagem6
      FROM tbl_cat_produto, tbl_produto, tbl_detalhe_produto, tbl_imagem_produto WHERE tbl_produto.id_produto = tbl_detalhe_produto.produto_id AND tbl_produto.id_produto = tbl_imagem_produto.produto_id ORDER BY RAND()';
      $resultado = mysql_query($sql)
      or die ("Não foi possível realizar a consulta.");
      $row1=mysql_fetch_array($resultado);
      $sql = "SELECT  tbl_sub_universo.id_subuniverso, tbl_sub_universo.subuniverso, tbl_sub_universo.universo_id, tbl_actividade.id_actividade, tbl_actividade.entidade, tbl_actividade.legenda, tbl_actividade.subuniverso_id, tbl_actividade.det, tbl_actividade.preco, tbl_actividade.data, tbl_detalhe_actividade.actividade_id, tbl_detalhe_actividade.periodo, tbl_detalhe_actividade.descricao, tbl_detalhe_actividade.programa, tbl_detalhe_actividade.informacoes, tbl_detalhe_actividade.actividades, tbl_detalhe_actividade.localizacao, tbl_detalhe_actividade.locais, tbl_detalhe_actividade.servicos, tbl_imagem_produto.id_imagem, tbl_imagem_produto.imagem1,tbl_imagem_produto.imagem2, tbl_imagem_produto.imagem3, tbl_imagem_produto.imagem4, tbl_imagem_produto.imagem5, tbl_imagem_produto.imagem6, tbl_imagem_produto.actividade_id FROM  tbl_sub_universo, tbl_actividade, tbl_detalhe_actividade, tbl_imagem_produto WHERE tbl_actividade.id_actividade =tbl_imagem_produto.actividade_id AND tbl_actividade.id_actividade =tbl_detalhe_actividade.actividade_id ORDER BY RAND()";
      $row2=mysql_fetch_array($resultado);
      $query='SELECT * FROM tbl_banner ORDER BY RAND()';
      $resultado = mysql_query($query);
      echo' <?xml version=\"1.0\"?>
      <home_left_headline>
      <bgimg>'.$dir2.''.$row1['imagem1'].'</bgimg>
      </home_left_headline>
      <home_flash>';
      while($row = mysql_fetch_array($resultado)) {
      echo'<swf headimg="" bgimg="" msgimg="" leftthrow="" rightthrow=""></swf>';
      echo'</home_flash>';
      echo'<promotop>
      <promo img="" title="" url="" ><![CDATA[]]></promo>
      </promotop>';
      mysql_close($link);
