6 Replies Latest reply on Sep 27, 2011 9:08 AM by Neonphotos
    write "inch" in scripts
    NEON LAI
      Hi
      The following is the script i wrote. I want to change the "point" {200,300} to "inch" {4.5i,5i} in demension.
      After i change it , i cannot run the script. Does anybody know how to input "inch" instead of "point".
      Many thanks, Neon
      tell application "Adobe InDesign CS5"
        tell pages of active document
        resize item 1 in inner coordinates from center anchor by replacing current dimensions with values {200, 300}
        end tell
      end tell
        • 1. Re: write "inch" in scripts
          csm_phil Level 4
          Hi Neon,
          Try the below code in InDesign Scripting Guide provided.
          set myDocument to active document
          tell view preferences of myDocument
          set myOldXUnits to horizontal measurement units
          set myOldYUnits to vertical measurement units
          set horizontal measurement units to points
          set vertical measurement units to points
          end tell
          --At this point, you can perform any series of script actions that depend on
          --the measurement units you’ve set. At the end of the script, reset
          --the measurement units to their original state.
          set horizontal measurement units to myOldXUnits
          set vertical measurement units to myOldYUnits
          end tell
          end tell
          And also you can try this.
            resize item 1 in inner coordinates from center anchor by replacing current dimensions with values {"4.5 in", "5 in"}
            end tell
          end tell
          Thx
          csm_phil
          • 2. Re: write "inch" in scripts
            NEON LAI Level 1
            Hi Phil, thanks for your advice. However, i got the message as attached when i input "inch" as the way advised.
            Neon
            • 3. Re: write "inch" in scripts
              csm_phil Level 4
              Hi Neon,
              Try this below AS code.
                      set horizontal measurement units to inches
                      set vertical measurement units to inches
                      tell pages of myDocument
                      end tell
                  end tell
              end tell
              thx
              csm_phil
              • 4. Re: write "inch" in scripts
                NEON LAI Level 1
                Hi Phil,
                Thanks and tried your AS code. However, the result is same. I can still change the document size.
                But  i cannot change the input values from points {200, 300} to inches {"4.5 in", "5 in"}.
                • 5. Re: write "inch" in scripts
                  Marc Autret Level 4
                  resize, resolve, and similar PageItem methods expect dimensions or locations in points—unless the reference point is specified relative to a page with consideringRulerUnits set to true.
                  Hence I suggest you use the UnitValue helper to convert inches into points.
                  Marc
                  • 6. Re: write "inch" in scripts
                    Neonphotos
                    Hi Marc,
                    Thanks for your advice. However, i am new in scripting and it seems a little complicated to me. Would you show me the complete scripts
                    then i just paste it onto script editor for the trial, many thanks
                    Neon
