2 Replies Latest reply on Sep 25, 2011 11:48 PM by relaxatraja
    Helllllp --clips, subclips, root timelines?!
    thequietly
      Idiot alert, everyone. Apologies in advance...
      I've been asked to create a short animation cycle in Flash, but I've never touched the program in my life. I was given the following instructions:
      - the 0,0 position must line up with the center of the characters
      body, so that means the legs should be centered on the X axis and the
      0 Y axis lines up with the neck placement.
      - the head clip must be animated but empty. I would animate the head
      normally then remove the subclip from inside the animated clip.
      - all animations must be on the same root timeline of the movieclip.
      subclip animations will not work.
      - all clips / tweens should be named properly according to their
      stage and body type and placed inside a folder in the flash library
      - base movie runs at 24 FPS so keep in mind when creating timing
      After beating my head against a wall for two days, I've got the character imported and animated, and (I think, at least) properly positioned. Now I'm completely baffled and I need a little hand-holding to get through the last few steps... I would really appreciate any help anyone could give me. I'm used to paper.
