3 Replies Latest reply on Jan 19, 2012 11:28 PM by turtle06
    Flash Builder - RDS - LCDS - 1020: Method marked override must override another method
    Wimmerke
      I'm using RDS data modeller, the RDS fml file is working okay,
      I can work with the tables, use services
      but when I try to run the application I get prolems, and the problem states:
      DescriptionResourcePathLocationType
      1020: Method marked override must override another method._CityEntityMetadata.as/xoffer/src/xofferline 219Flex Problem
      This issue extract is: for example: _CityEntityMetadata.as
          override public function getPropertyType(propertyName:String):String
              if (model_internal::allProperties.indexOf(propertyName) == -1)
                  throw new Error(propertyName + " is not a property of City");
              return model_internal::propertyTypeMap[propertyName];
      this for some tables
      how does this present, I didn't do sth special, followed the how to online, already reinstalled the whole thing (flash builder 4.5.1, modeller 3.1.1)
      workflow:
      -> created in MySQL the Database
      -> used the RDS config (this works)
      -> generate the code and push to the server
      -> make a datagrid and link it to a service
      -> play => errors get detected
      ps when I delete the override it is ok, but I don't think this should be the case....
