• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Ordering lists
Enthusiast ,
Sep 25, 2011 Sep 25, 2011
I have a query that retrieves a UID (camp_uid) and with each camp_uid is field camp_form_fields which contains a numerical list, as an example
camp_uid: 375 , camp_form_fields: 1,4,6,7,8
camp_uid: 377 , camp_form_fields: 4,7,8
camp_uid: 390 , camp_form_fields: 9,7,6,3
camp_uid: 392 , camp_form_fields: 3,4
What I need to do is order the camp_uid into a list, so that the one which has the smallest camp_form_fields is listed first, followed by the next smallest etc, so that the example data above would give the result
camp_list = 392,377,390,375
I guess there is no easy way to get SQL to do it and I've been pondering on how to do this in CF without having too many queries within a loop
Perhaps there is somebody out there that has had to do something similar before? Appreciate any ideas
Mark
TOPICS
Advanced techniques
Views
855
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Sep 25, 2011 Sep 25, 2011
I got it!! That's a great solution, thanks again for all of your help
Code:
<!--- GET THE LIST --->
<CFQUERY name="GetFieldList" DATASOURCE="#datasource#">
    SELECT 1000 AS TempValue,camp_form_fields,camp_uid
    FROM campaigns
    WHERE camp_uid IN (370,372,373,374,375,376,377,378,379)
</CFQUERY>
<!--- LOOP OVER CHECKING LENGTH OF EACH ITEM IN LIST AND CHANGE THE VALUE IN THE QUERY --->
<CFLOOP QUERY="GetFieldList">
<CFSET GetFieldList.TempValue = #Len(GetFieldList.camp_form_fields)#>
</CFLOOP>
<!--- QUE
Votes
Translate
Translate
LEGEND ,
write your query so that it contains constant integer, such as 1000, in the select clause.  Then loop through the results and change that field based on the the value of camp_list.  Then do a Q of Q with an order by clause.  Your answer will be the valuelist if camp_uid from this last query.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Thanks again for the assistance
Unfortunately, my SQL skills are not that advanced, to be perfectly honest I'm not quite sure what you mean about the constant integer within the query. I can do Q of Q, so if I saw a rough example of what you are thinking maybe I can figure it out
Mark
Votes
Translate
Translate
Report
Report
LEGEND ,
select 1000 NumberToBeChangedLater
from atable
where etc
Votes
Translate
Translate
Report
Report
Enthusiast ,
OK, I changed the results of the query using a loop, by assigning the length ot each list to that number, and then I run a query over that query, somebody showed me how to do that a while ago, but I can't remember how to query over an existing query that is in memory, how do I do that? I know it's simple, when you know how
Looks like I am almost there, great solution with little code.
    FROM campaigns
</CFLOOP>
<br>
<CFDUMP VAR="#Getfieldlist#">
results:
query
RESULTSET
query
CAMP_FORM_FIELDSCAMP_UIDTEMPVALUE
14,1 374 1000
22,1,4 375 1000
31 378 1000
41,2,4,5,6 379 1000
CACHEDfalse
EXECUTIONTIME0
SQLSELECT 1000 AS TempValue,camp_form_fields,camp_uid FROM campaigns WHERE camp_uid IN (370,372,373,374,375,376,377,378,379)
query
RESULTSET
query
14,1 374 3
22,1,4 375 5
31 378 1
41,2,4,5,6 379 9
CACHEDfalse
EXECUTIONTIME0
Votes
Translate
Translate
Report
Report
Enthusiast ,
LATEST
Code:
    FROM campaigns
</CFQUERY>
</CFLOOP>
<!--- QUERY THE ORIGINAL QUERY AND USE ORDER TO PULL RESULTS BASED ON THE LENGTH --->
<CFQUERY dbtype="query" name="SortResults">
SELECT *
FROM GetFieldList
ORDER BY TempValue
</CFQUERY>
Votes
Translate
Translate
Report
Report
Enthusiast ,
OK I wrote this test script, with the results below.. not sure what you mean for the rest of it? I CFLOOP QUERY="queryname" but what am I supposed to do with the results?
SELECT 1000,camp_form_fields
FROM campaigns
query
RESULTSET
query
CAMP_FORM_FIELDSCOMPUTED_COLUMN_1
14,1 1000
22,1,4 1000
31 1000
41,2,4,5,6 1000
CACHEDfalse
EXECUTIONTIME0
SQLSELECT 1000,camp_form_fields FROM campaigns WHERE camp_uid IN (370,372,373,374,375,376,377,378,379)
Votes
Translate
Translate
Report
Report
LEGEND ,
First, you have to include the camp_uid in your select clause.  Next, when you are looping through the query, set computed_column_1 to the listlen of camp_form_fields, or whatever criteria you use to determine it's length.
Votes
Translate
Translate
Report
Report
Resources
Documentation
