5 Replies Latest reply on Sep 26, 2011 2:09 PM by Harbs.
    Applying master to a collection of pages
    Ken Krugh
      Hello all,
      Still in CS3, VB.
      Back in 2008 I did a post on this same subject (http://forums.adobe.com/message/3312350#3312350) and Harbs was kind enough to show it to me in Java script.
      Now that it's been a while I'm wondering if anyone has clue as to why this doesn't work in VB:
      Set pgs = InD.ActiveDocument.Pages.ItemByRange(149, 152)
      pgs.AppliedMaster = InD.ActiveDocument.MasterSpreads.Item("LNG-TXT")
      But his DOES work in Javascript:
      var thepgs = app.activeDocument.pages.itemByRange(148,151);
      thepgs.appliedMaster = app.activeDocument.masterSpreads.item("LNG-TXT");
      Many thanks,
      Ken
        • 1. Re: Applying master to a collection of pages
          Harbs. Level 6
          Does VB take an index as an argument?
          Try:
          Set pgs = InD.ActiveDocument.Pages.ItemByRange(InD.ActiveDocument.Pages.item(149), InD.ActiveDocument.Pages.item(152))
          • 2. Re: Applying master to a collection of pages
            Ken Krugh Level 1
            Hey Harbs,
            Thanks a gain for taking a crack at this. Unfortunately I've tried that. I'm beginning to think it just isn't in the VB model, or something.
            VB has a TypeName() function that returns a string with the type of variable passed. So when a text frame is selected and I do this:
            set MyTxtFrame = InD.Selection(1)
            MsgBox TypeName(MyTxtFrame)
            I get a message box that says "TextFrame."
            When I pass pgs to TypeName I get "Objects" and when I pass pgs(1) I get "Page" so I'm nearly sure the collection is getting created OK. I can even set the AppliedMaster of one of the pages within the collection like this:
            pgs(1).AppliedMaster = InD.ActiveDocument.MasterSpreads("LNG-TXT")
            It's just the darn application of the master to the collection that simply doesn't work.
            Currently I'm building a string that is the Java code and running the DoScript command, which works MUCH faster than itterating through all the pages.
            Thanks again,
            Ken
            • 3. Re: Applying master to a collection of pages
              Harbs. Level 6
              Ah. I seem to remember that itemByRange in VB is a VB functionality which is really more of an array than an InDesign collection. You can't use methods or set properties to arrays. It only works for collections.
              I don't use VB, so my memory is a bit fuzzy.
              Try checking the type of the object you get from ItemByRange. What is it?
              • 4. Re: Applying master to a collection of pages
                Ken Krugh Level 1
                Just just as TypeName(pgs) returns "Objects," this:
                TypeName(InD.ActiveDocument.Pages.ItemByRange(InD.ActiveDocument.Pages.Item(161), InD.ActiveDocument.Pages.Item(164)))
                also returns "Objects."
                Something, somewhere made me think that you work primarily in Windows. True? Do you have any recommendations for a development environment for Java scripts? Preferrably something that has a GUI for developing forms?
                Ken
                • 5. Re: Applying master to a collection of pages
                  Harbs. Level 6
                  Nope. My primary machine is Mac.
