3 Replies Latest reply on Sep 26, 2011 3:07 PM by BobTheCoolGuy
    Button Icon Disappears when Using Different Theme
    BobTheCoolGuy
      Hello all,
      I noticed then when I switch my project's theme to ColbaltGraphical (located under the Flex 4 Graphical Samples category) from the default spark theme, the icons on my spark buttons no longer show up.
      I set these by using the icon style in the tag normally as such:
      <s:Button icon="@Embed('libs/myIcon.png')" width="18" height="18"/>
      I assume this is some problem with the button skin or something - is there an easy way to fix this?
      Thanks for the help!
        • 1. Re: Button Icon Disappears when Using Different Theme
          BobTheCoolGuy Level 1
          I think the theme is using this skin for the buttons.  Would the skin affect it?  I wasn't really able to find any mention of the icon in the default skin or this one.
          ADOBE SYSTEMS INCORPORATED
          Copyright 2009 Adobe Systems Incorporated
          All Rights Reserved.
          NOTICE: Adobe permits you to use, modify, and distribute this file
          in accordance with the terms of the license agreement accompanying it.
          <!--- The default skin class for the Spark Button component.
          @langversion 3.0
          @playerversion Flash 10
          @playerversion AIR 1.5
          @productversion Flex 4
          <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
                       xmlns:fb="http://ns.adobe.com/flashbuilder/2009" minWidth="21" minHeight="24" alpha.disabled="0.5">
              <!-- host component -->
              <fx:Metadata>
                  <![CDATA[
                   * @copy spark.skins.default.ApplicationSkin#hostComponent
                  [HostComponent("spark.components.Button")]
              </fx:Metadata>
              <!-- states -->
              <s:states>
                  <s:State name="up" />
                  <s:State name="over" />
                  <s:State name="down" />
                  <s:State name="disabled" />
              </s:states>
              <!-- Layer 1: border -->
              <s:Rect id="border" left="0" right="0" top="0" bottom="0" radiusX="4">
                  <s:fill>
                      <s:LinearGradient rotation="90">
                          <s:GradientEntry color="0x426089"
                                           color.over="0x5C85B8"
                                           color.down="0x263852"
                                           alpha="1.0" />
                          <s:GradientEntry color="0x304663"
                                           color.over="0x43658F"
                                           color.down="0x2E4260"
                                           alpha="1.0" />
                      </s:LinearGradient>
                  </s:fill>
              </s:Rect>
              <!-- Layer 2: innerBorder -->
              <s:Rect id="innerBorder" left="1" right="1" top="1" bottom="1" radiusX="3">
                  <s:fill>
                          <s:GradientEntry color="0x557FB5"
                                           color.over="0x77B1D2"
                                           color.down="0x344E6D"
                                           alpha="1.0" />
                          <s:GradientEntry color="0x42628A"
                                           color.over="0x5C89B9"
                                           color.down="0x3E5A80"
                                           alpha="1.0" />
                      </s:LinearGradient>
                  </s:fill>
              </s:Rect>
              <!-- Layer 3: insetBorder -->
              <s:Rect id="insetBorder" left="2" right="2" top="2" bottom="2" radiusX="2">
                  <s:fill>
                                           color.over="0x426089"
                                           alpha="1.0" />
                                           color.over="0x304663"
                                           alpha="1.0" />
                      </s:LinearGradient>
                  </s:fill>
              </s:Rect>
              <!-- Layer 4: fill -->
              <s:Rect id="fill" left="3" right="3" top="3" bottom="3" radiusX="1">
                  <s:fill>
                          <s:GradientEntry color="0x446690"
                                           color.over="0x446690"
                                           color.down="0x2B405C"
                                           alpha="1.0"/>
                          <s:GradientEntry color="0x496C9A"
                                           color.over="0x496C9A"
                                           color.down="0x2F4563"
                                           alpha="1.0"
                                           ratio=".1"/>
                          <s:GradientEntry color="0x3D5A80"
                                           color.over="0x3D5A80"
                                           color.down="0x354D6F"
                                           alpha="1.0"
                                           ratio=".9"/>
                          <s:GradientEntry color="0x385275"
                                           color.over="0x385275"
                                           color.down="0x314867"
                                           alpha="1.0"
                                           ratio=".1"/>
                      </s:LinearGradient>
                  </s:fill>
              </s:Rect>
              <!-- layer 5: text -->
                  @copy spark.components.supportClasses.ButtonBase#labelDisplay
              <s:Label id="labelDisplay"
                       textAlign="center"
                       verticalAlign="middle"
                       lineBreak="toFit"
                       maxDisplayedLines="1"
                       horizontalCenter="0" verticalCenter="1"
                       left="10" right="10" top="2" bottom="2"
              </s:Label>
          </s:Skin>
          • 2. Re: Button Icon Disappears when Using Different Theme
            Flex harUI Adobe Employee
            If the skin doesn’t support icons, then no icons will be shown.
            • 3. Re: Button Icon Disappears when Using Different Theme
              Thank you.  I solved the problem by simply making the ButtonSkin provided with the theme extend SparkButtonSkin instead of just Skin.  This let the skin support the icon and fixed the problem.
