13 Replies Latest reply on Oct 10, 2011 7:43 AM by Colin Brougham
    Problem exporting Quicktime Mov with Premiere / Media Encoder
    TimoColeman
      I have a MOV-file which has been exported from Final Cut. I imported and edited it in Premiere CS 5.5 and then tried to export again to Quicktime Mov. Problem is that the output looks terrible. There is some kind of "Motion bluriness" or fuzziness in the video and looks like there is a maybe "frame rate problem".
      Does anyone know what the problem is? I use "real" Quicktime from Apple website.
      Here is the information of my Premiere project:
      Editing mode: DV PAL
      Timebase: 25,00fps
      Video Settings
      Frame size: 720h 576v (1,4587)
      Frame rate: 25,00 frames/second
      Pixel Aspect Ratio: D1/DV PAL Widescreen 16:9 (1.4587)
      Fields: Lower Field First
      Here is the information (Mediainfo) of the original MOV:
      Format                           : MPEG-4
      Format_Commercial_IfAny          : DVCPRO
      Format profile                   : QuickTime
      Codec ID                         : qt
      File size                        : 2.06 GiB
      Duration                         : 9mn 42s
      Overall bit rate                 : 30.3 Mbps
      Encoded date                     : UTC 2011-08-17 18:12:37
      Tagged date                      : UTC 2011-08-30 17:05:26
      Writing library                  : Apple QuickTime
      ©TSC                             : 25
      ©TSZ                             : 1
      Video
      Format                           : DV
      Codec ID                         : dvpp
      Codec ID/Hint                    : DVCPRO
      Duration                         : 9mn 42s
      Bit rate mode                    : Constant
      Bit rate                         : 24.4 Mbps
      Width                            : 703 pixels
      Original width                   : 720 pixels
      Height                           : 576 pixels
      Display aspect ratio             : 16:9
      Frame rate mode                  : Constant
      Frame rate                       : 25.000 fps
      Standard                         : PAL
      Color space                      : YUV
      Chroma subsampling               : 4:1:1
      Bit depth                        : 8 bits
      Scan type                        : Interlaced
      Scan order                       : Bottom Field First
      Compression mode                 : Lossy
      Bits/(Pixel*Frame)               : 2.414
      Stream size                      : 1.95 GiB (95%)
      Language                         : English
      Tagged date                      : UTC 2011-08-17 18:15:18
      And here is the information about exported video:
      Format                           : MPEG-4
      Codec ID                         : qt
      Duration                         : 9mn 42s
      Encoded date                     : UTC 2011-09-24 19:59:53
      Tagged date                      : UTC 2011-09-24 20:01:56
      ©TIM                             : 00:00:00:00
      ©TSC                             : 25
      ©TSZ                             : 1
      Video
      Format                           : DV
      Codec ID                         : dvcp
      Duration                         : 9mn 42s
      Width                            : 720 pixels
      Height                           : 576 pixels
      Original display aspect ratio    : 4:3
      Standard                         : PAL
      Color space                      : YUV
      Chroma subsampling               : 4:2:0
      Bit depth                        : 8 bits
      Bits/(Pixel*Frame)               : 2.357
      Language                         : English
      And final information about my computer:
      CPU
      Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
      RAM
      8.0 GB
      OS
      Microsoft Windows 7 Service Pack 1 (build 7601), 64-bit (Professional)
      Video Card
      AMD Radeon HD 6900 Series
