3 Replies Latest reply on Oct 14, 2011 9:58 PM by Shongrunden
    Make Mobile Scroller 'Spring Back' Programmatically
    pcoyne1979
      Hi, I am having a problem with the Flex 4.5 Scroller when used in a mobile application. If I set the horizontalScrollPosition/verticalScrollPosition properties to negative values programmatically, then the scroller content does not spring back automatically. Is there a method I could call on the mobile skin to make it perform the springing? I tried to dispatch a TouchInteractionEvent but it didn't work.
        • 1. Re: Make Mobile Scroller 'Spring Back' Programmatically
          Shongrunden Adobe Employee
          I don't believe there is currently an API that supports something like this.  Can you consider playing an effect on the verticalScrollPosition, for example:
                         xmlns:s="library://ns.adobe.com/flex/spark">
              <fx:Declarations>
                  <s:Animate id="an" target="{tripList.dataGroup}" duration="500">
                      <s:motionPaths>
                          <s:SimpleMotionPath property="verticalScrollPosition" valueTo="0"/>
                      </s:motionPaths>
                      <s:easer>
                          <s:Power exponent="3" />
                      </s:easer>
                  </s:Animate>
              </fx:Declarations>
              <s:controlBarContent>
                  <s:Button label="set vsp" click="tripList.dataGroup.verticalScrollPosition = -100" />
                  <s:Button label="scroll back" click="an.play()" />
              </s:controlBarContent>
              <s:List id="tripList" width="100%" height="100%">
                  <s:dataProvider>
                      <s:ArrayList>
                          <s:source>
                              [0,1,2,3,4,5,6,7,8,9]
                          </s:source>
                      </s:ArrayList>
                  </s:dataProvider>
              </s:List>
          </s:Application>
          • 2. Re: Make Mobile Scroller 'Spring Back' Programmatically
            pcoyne1979 Level 1
            Hi, yes I tried this and also with TweenLite. It works fine but I have to put extra logic in the gesture handler which probably slows things down. It would be better if there was just a method to call to make it spring.
            • 3. Re: Make Mobile Scroller 'Spring Back' Programmatically
              There currently isn't an API exposed for this.  Please vote for and/or leave a comment with your use case on this enhancement request: http://bugs.adobe.com/jira/browse/SDK-28789
