1 Reply Latest reply on Sep 26, 2011 10:56 PM by VideoPep
    Track score from Adobe Presenter 7
    mdalfesullah
      I am creating a LMS portal and planning to use adobe presenter as the online training quiz builder. After publishing the quiz (scorm 2004), I am not sure how to track the user's score. I already google it but could not find any working example. After searching google, I came to this point that I need javascript to track the score. But no luck yet.
      If anyone knows, could you please help me in regards to this.
      Alfes
        • 1. Re: Track score from Adobe Presenter 7
          VideoPep Level 2
          Hi Alfes,
          1) You are setting up portal from already existing LMS like Moodle,sumtotal etc.; then in that case you can contact them to undestand what setting you need to do to create portal.
          2) If you are going create your own LMS server then you can search for SCORM 2004 Standard docs on internet, then those docs will guide you through required APIs which you need at server side setup.
          Once server is setup from either of the way , you Publish Adobe Presenter in zip format and upload it to LMS and you can see the score. No extra coding is required for Adobe Presenter.
          Regards,
          Shubhi
