2 Replies Latest reply on Sep 27, 2011 9:37 PM by rabinprithvi
    ComboBox Behaviour ???
    rabinprithvi
      I am using Flash Builder 4.0.
      I am confused about the behaviour of combobox when an item is deleted in the dataprovider.
      Following is the user interaction
      Step1: User enters a name in the texfield
      Step2 : User Clicks a button
      Step3. Name is added to combobox using  ArrayCollection as data provider (Use item renderer to display delete button for every item)
      Step4. Repeat the above steps three times to populate three items in the combobox
      Step5: Select the second item.
      Step6 : Open the combobox and delete the first item
      Step7: Now the selected item is the third item !!!!...... not the second item which was selected in Step 5.
      How the last item gets selected ?
      I think that flex does not bother about which is previously selected item, it goes ahead and selects the previously selected index.
      Am I Correct?
      If so, what is the work around ???
      ______________________________
      Thanks for your time.
      Rabin.
      Here is the code for the 3 files I used for prototype.
      Main Application.mxml
                                       xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
                                       creationComplete="application1_creationCompleteHandler(event)">
                <fx:Script>
                          <![CDATA[
                                    import events.UserReportFilterDeleteEvent;
                                    import mx.collections.ArrayCollection;
                                    import mx.controls.Alert;
                                    import mx.core.FlexGlobals;
                                    import mx.events.FlexEvent;
                                    import mx.utils.object_proxy;
                                    import spark.events.IndexChangeEvent;
                                    [Bindable]
                                    private var ac:ArrayCollection = new ArrayCollection();
                                    private var previousObject:Object;
                                    protected function button1_clickHandler(event:MouseEvent):void
                                              ac.addItem(ti.text);
                                    protected function application1_creationCompleteHandler(event:FlexEvent):void
                                              FlexGlobals.topLevelApplication.addEventListener(UserReportFilterDele teEvent.FILTER_DELETED,deletedHandler);
                                    private function deletedHandler(e:UserReportFilterDeleteEvent):void
                                              var object:Object = e.data;
                                              ac.removeItemAt(ac.getItemIndex(object));
                </fx:Script>
                <s:layout>
                          <s:HorizontalLayout/>
                </s:layout>
                <s:TextInput id="ti"/>
                <s:Button label="Add" click="button1_clickHandler(event)"/>
                <s:ComboBox id="cb" dataProvider="{ac}" itemRenderer="renderers.FilterRenderer" />
      </s:Application>
      FilterRenderer.mxml
      <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                              autoDrawBackground="true">
                <s:layout>
                </s:layout>
                <fx:Script>
                          <![CDATA[
                                    protected function button1_mouseDownHandler(event:MouseEvent):void
                                              var deleteEvent:UserReportFilterDeleteEvent = new UserReportFilterDeleteEvent(UserReportFilterDeleteEvent.FILTER_DELETED,data);
                                              FlexGlobals.topLevelApplication.dispatchEvent(deleteEvent);
                </fx:Script>
                <s:Label text="{data}"/>
                <s:Button label="X" width="28" mouseDown="button1_mouseDownHandler(event)"/>
      </s:ItemRenderer>
      UserReportFilterDeleteEvent.as
      package events
                import flash.events.Event;
                public class UserReportFilterDeleteEvent extends Event
                          public static const FILTER_DELETED:String = "filterDeletedUserReportFilterDeleteEvent";
                          public var data:Object;
                          public function UserReportFilterDeleteEvent(type:String,data:Object, bubbles:Boolean=true, cancelable:Boolean=false)
                                    this.data = data;
                                    super(type, bubbles, cancelable);
                          override public function clone():Event
                                    return new UserReportFilterDeleteEvent(UserReportFilterDeleteEvent.FILTER_DELETED,data,bubbles,cance lable);
