2 Replies Latest reply on Jul 3, 2012 7:25 AM by murphysm
    Detect present rating
    Pedro Cortez Marques Level 3
      I want a function to detect if the info of an image (not new, but opened from the disk) has indicated a rating (1, 2, 3, 4 or 5 stars)?
      I want to open the ACR and (only in some images) mark them with 1 star.
      In photoshop, when they are all already opened, I want to diferenciate a behavior of the script depending on the detection of the rating (stars).
      Is this possible?
      Tks
        • 1. Re: Detect present rating
          c.pfaffenbichler Level 9
          Does this work?
          // from a post by michael l hale;
          var rating = app.activeDocument.xmpMetadata.rawData.toString().match(/\<xmp:Rating\>(.+)\<\/xmp:Rating\>/)[1];
          alert (rating);
          • 2. Re: Detect present rating
            murphysm
            Here is some code that our developer created.  It views the documents photoshop rating and saves to a new location with a new name based on the rating.  It works great.  Oh, and you'll see in there that a dialogue window pops up with radio buttons if no photoshop rating is found.  Then the user can choose 1 - 5 based on where it should be going.
            loadXMPLibrary();
            var xmp = new XMPMeta(docRef.xmpMetadata.rawData);
            documentRating = xmp.getProperty(XMPConst.NS_XMP, "Rating");
            var FillColour = new SolidColor;
            FillColour.rgb.hexValue = 'ffffff';
            app.backgroundColor= FillColour;
            if(documentRating!=undefined && documentRating.value!=0){
                hasRating = true;
            else{
                var dlg = new Window("dialog", "Choose Position");
                dlg.alertBtnsPnl = dlg.add("panel", undefined, PANEL_MESSAGE_TEXT);
                dlg.alertBtnsPnl.p1Btn = dlg.alertBtnsPnl.add("radiobutton", undefined, positionStringArray[0]);
                dlg.alertBtnsPnl.p2Btn = dlg.alertBtnsPnl.add("radiobutton", undefined, positionStringArray[1]);
                dlg.alertBtnsPnl.p3Btn = dlg.alertBtnsPnl.add("radiobutton", undefined, positionStringArray[2]);
                dlg.alertBtnsPnl.p4Btn = dlg.alertBtnsPnl.add("radiobutton", undefined, positionStringArray[3]);
                dlg.alertBtnsPnl.p5Btn = dlg.alertBtnsPnl.add("radiobutton", undefined, positionStringArray[4]);
                dlg.alertBtnsPnl.p6Btn = dlg.alertBtnsPnl.add("radiobutton", undefined, positionStringArray[5]);
                dlg.alertBtnsPnl.okBtn = dlg.alertBtnsPnl.add("button", undefined, "OK", {name:"ok"});
                dlg.alertBtnsPnl.cancelBtn = dlg.alertBtnsPnl.add("button", undefined, "Cancel", {name:"cancel"});
                var dialogReturn = dlg.show();
                if(dialogReturn==1){//if dialogReturn is one, the ok button was clicked, if it equals 2 the cancel button was clicked
                    if(dlg.alertBtnsPnl.p1Btn.value){documentRating=1;};
                    if(dlg.alertBtnsPnl.p2Btn.value){documentRating=2;};
                    if(dlg.alertBtnsPnl.p3Btn.value){documentRating=3;};
                    if(dlg.alertBtnsPnl.p4Btn.value){documentRating=4;};
                    if(dlg.alertBtnsPnl.p5Btn.value){documentRating=5;};
                    if(dlg.alertBtnsPnl.p6Btn.value){documentRating=6;};
            if(documentRating==undefined){
                if(dialogReturn!=2){
                    alert ("You've failed to select a rating, please try again");
            else if(dialogReturn!=2){
                selRef.makeWorkPath(0);
                var thisWorkPath = docRef.pathItems.getByName("Work Path");
                thisWorkPath.makeSelection();
                try{
                    var existingWorkPath = docRef.pathItems.getByName(PATH_TEXT);
                    existingWorkPath.remove();
                catch(e){
                thisWorkPath.name = PATH_TEXT;
                xmp.setProperty(XMPConst.NS_XMP, "Rating", documentRating);
                docRef.xmpMetadata.rawData = xmp.serialize(XMPConst.SERIALIZE_USE_COMPACT_FORMAT);
