6 Replies Latest reply on Oct 1, 2011 10:28 AM by sasientry
    want to select path or mask
    sasientry
      if file have path named "Path 1"
      i want selection from that path
      else if there is no path  please check channel named "Alpha 1" is there i want selection from that channel
      please help me
        • 1. Re: want to select path or mask
          Muppet Mark Level 5
          Depending on the state of your documents you may be able to use something like this…
          var doc = app.activeDocument;
          if ( doc.pathItems.length > 0 ) {
               doc.pathItems[0].makeSelection( 0, true, SelectionType.REPLACE );
               doc.pathItems[0].deselect();
          } else {
               if ( doc.channels[ doc.channels.length-1 ].kind == ChannelType.SELECTEDAREA ) {
                    doc.selection.load( doc.channels[ doc.channels.length-1 ], SelectionType.REPLACE, false );
          It should use a path first then if no paths the last channel… Otherwise it will do nothing…
          • 2. Re: want to select path or mask
            sasientry Level 1
            hi
            i have two selection type
            path or mask
            if i have path  i want selection from the path
            if i dont have path i want selection from the mask
            selection taken from path or mask
            • 3. Re: want to select path or mask
              Muppet Mark Level 5
              Did you try it… This would look for the alpha by name rather than position…
              } else {
                        try {
                             doc.selection.load( doc.channels.getByName('Alpha 1'), SelectionType.REPLACE, false );
                        } catch(e) {}
              • 4. Re: want to select path or mask
                sasientry Level 1
                it show this error
                • 5. Re: want to select path or mask
                  Muppet Mark Level 5
                  That will learn me to be lazy and copy/paste/edit in the browser window…
                  } else {
                            try {
                            } catch(e) {}
                  Would have thought you could have sorted that mistake thou…
                  • 6. Re: want to select path or mask
                    sasientry Level 1
                    super i got good answer thank u very much
