4 Replies Latest reply on Sep 29, 2011 8:01 AM by kglad
    Sliding images
    sam2986
      I have a header for a website that has three buttons on the left and when you click on each one it leads to another image that slides in from the right. I am trying to change some of the code in this because it is from someone that does not currently work here anymore and I am not by any means a flash person. I can do simple things so hopefully I will comprehend any answers I get.
      Here is what I want this header to do... Right now the only way it changes images is if you click on one of the buttons on the left, I want it to be able to also rotate automatically through them also. Say rotate to the next image every 10 seconds or so. I am pasting the code below  and any help I can get on this would be greatly appreciated.
      Here is the code from the action layer....
      var currentPosition:Number = contentHold.content1._x;
      var startFlag:Boolean = false;
      menuSlide = function (input:MovieClip) {
                  if (startFlag == false) {
                              startFlag = true;
                              var finalDestination:Number = input._x;
                              var distanceMoved:Number = 0;
                              var distanceToMove:Number = Math.abs(finalDestination-currentPosition);
                              var finalSpeed:Number = .3;
                              var currentSpeed:Number = 0;
                              var dir:Number = 1;
                              if (currentPosition<=finalDestination) {
                                          dir = -1;
                              } else if (currentPosition>finalDestination) {
                                          dir = 1;
                              this.onEnterFrame = function() {
                                          currentSpeed = Math.round((distanceToMove-distanceMoved+1)*finalSpeed);
                                          distanceMoved += currentSpeed;
                                          contentHold._x += dir*currentSpeed;
                                          if (Math.abs(distanceMoved-distanceToMove)<=1) {
                                                      contentHold._x = maskMovie._x-currentPosition+dir*distanceToMove;
                                                      currentPosition = input._x;
                                                      startFlag = false;
                                                      delete this.onEnterFrame;
      b1.onRelease = function() {
                  menuSlide(contentHold.content1);
      b2.onRelease = function() {
                  menuSlide(contentHold.content2);
      b3.onRelease = function() {
                  menuSlide(contentHold.content3);
        • 1. Re: Sliding images
          Ron Colmen Level 2
          setInterval(yourFunction,10000); //1000=1sec
          • 2. Re: Sliding images
            sam2986 Level 1
            Rob, thanks for the quick response. So where would I want to insert this code? I am looking through it and I am not sure where I would want to insert it. Thanks again.
            • 3. Re: Sliding images
              sam2986 Level 1
              Also when you say (yourFunction) should I be inserting the movie clip that I want to rotate into these parenthasis? Thanks, so close to having this headache done and hopefully this is the last question.
              • 4. Re: Sliding images
                you can use:
                var menuSlideI:Number;
                var currentContent:Number = 1;
                var contentTotal:Number = 3;  // update this if you add more slides/buttons
                                         clearInterval(menuSlideI);
                                        currentContent=input._name.split("content")[1];
                                        startFlag = true;
                                        var dir:Number = 1;
                                                    dir = -1;
                                                    dir = 1;
        startFlag = false;
                menuSlideInterval=setInterval(menuSlide,10000,contentHold["content"+(1+currentContent%cont entTotal) ]);
