1 Reply Latest reply on Oct 3, 2011 10:17 PM by Joe ... Ward
    issues with drag and drop/file browse functionality in air file uploader
    madhooper
      Use Case: User can drag and drop a file into a datagrid or browse to the file and add it to the datagrid before uploading files to the server.
      The file browse functionality works fine. I put all the selected files in to an array and display them in a datagrid.
      Issue: I'm need to allow the user to also drag and drop a file into the datagrid from the file desktop and add that file to the upload que/datagrid.
      // Called to add file(s) for upload
                                    private function addFiles():void {
                                              _refAddFiles = new FileReferenceList();
                                              _refAddFiles.addEventListener(Event.SELECT, onSelectFile);
                                              _refAddFiles.browse();
      // Called when a file is selected via file browser
                                    private function onSelectFile(event:Event):void {
                                              var arrFoundList:Array = new Array();
        // Get list of files from fileList, make list of files already on upload list
                                              for (var i:Number = 0; i < _arrUploadFiles.length; i++) {
                                                        for (var j:Number = 0; j < _refAddFiles.fileList.length; j++) {
        if (_arrUploadFiles[i].name == _refAddFiles.fileList[j].name) {
        arrFoundList.push(_refAddFiles.fileList[j].name);
        _refAddFiles.fileList.splice(j, 1);
        j--;
                                              if (_refAddFiles.fileList.length >= 1) {
                                                        for (var k:Number = 0; k < _refAddFiles.fileList.length; k++) {
        _arrUploadFiles.push({
        file:_refAddFiles.fileList[k]});
                                                        listFiles.dataProvider = _arrUploadFiles;
                                                        tile.dataProvider = _arrUploadFiles;
                                                        listFiles.selectedIndex = _arrUploadFiles.length - 1;
                                              if (arrFoundList.length >= 1) {
                                                        Alert.show("The file(s): \n\n• " + arrFoundList.join("\n• ") + "\n\n...are already on the upload list. Please change the filename(s) or pick a different file.", "File(s) already on list");
                                              updateProgBar();
                                              scrollFiles();
                                              uploadCheck();
      Bad/Broken Code--------------------------- Called when user attempts to drop file into the datagrid.
      private function onDragEnter( event:NativeDragEvent ) :void
                                              DragManager.acceptDragDrop(this);
                                    private function onDragDrop( event:NativeDragEvent ) :void
                                              NativeDragManager.dropAction = NativeDragActions.COPY;
                                              var draggedfiles:Array = event.clipboard.hasFormat(flash.desktop.ClipboardFormats.FILE_LIST_FORMAT) as Array;
                                              NativeDragManager.acceptDragDrop(InteractiveObject(event.currentTarget));
                                              for each (var f:File in draggedfiles)
        //addFile( FileReference( f ) );
                                                        _arrUploadFiles.push( f );
      What am I missing? Any assistance would be greatly appreciated.
