3 Replies Latest reply on Sep 30, 2011 11:51 AM by AIF Bob
    PB Filter working in Toolkit, but fails to give same result in Flash Player
    jonnyswingpants Level 1
      I'm playing with the excellent LittlePlanet filter by Tom Beddard. The results in the PixelBender toolkit(2.6.453492)  are amazing, but when I try to use the PBJ as a filter in Flash the output is entirely different.
      I have built a few filters and implemented numerous others all with no problems and fantastic results, but LittlePlanet (I also have the same issue with the Escher Droste kernels) is being a pain.
      Here is the kernel that I'm using:
      #define PI 3.141592653589793
      #define TWOPI 6.283185307179586
      #define HALFPI 1.570796326794897
      #define PI180 0.017453292519943
      #define DEBUG 0
      <languageVersion : 1.0;>
      kernel LittlePlanet
      <   namespace : "com.subblue";
          vendor : "Tom Beddard - www.subblue.com";
          version : 2;
          displayname: "Little Planet";
          description : "Generates a stereographic projection from an equirectangular panorama image to create 'little planet' type images.";
          parameter float2 size
              minValue: float2(200, 200);
              maxValue: float2(4096, 4096);
              defaultValue: float2(480, 320);
              stepInterval: float2(1, 1);
              displayName: "Input image size";
              componentName: "Width|Height";
              aeDisplayName: "Input image size";
          // Seems buggy on OSX
              defaultValue: float2(1024, 512);
              parameterType: "inputSize";
          parameter float2 outputSize
              displayName: "Output image size";
              aeDisplayName: "Output image size";
          parameter float2 center
              minValue: float2(-1, -1);
              maxValue: float2(1, 1);
              defaultValue: float2(0, 0);
              stepInterval: float2(0.01, 0.01);
              componentName: "X|Y";
              displayName: "Center point";
              aeDisplayName: "Center point";
          parameter float longitude
              minValue: 0.0;
              maxValue: 360.0;
              defaultValue: 0.0;
              stepInterval: 0.5;
              displayName: "Longitude offset";
              aeDisplayName: "Longitude offset";
              aeUIControl:"aeAngle";
          parameter float latitude
              minValue: 0.0;
              maxValue: 360.0;
              defaultValue: 90.0;
              stepInterval: 0.5;
              displayName: "Latitude offset";
              aeDisplayName: "Latitude offset";
          parameter float rotate
              minValue: -360.0;
              maxValue: 360.0;
              defaultValue: 0.0;
              stepInterval: 0.5;
              displayName: "Rotate";
              aeDisplayName: "Rotate";
          parameter float zoom
              minValue: 0.1;
              maxValue: 10.0;
              defaultValue: 0.4;
              stepInterval: 0.01;
              displayName: "Zoom";
              aeDisplayName: "Zoom";
          parameter float wrap
              minValue: -2.0;
              maxValue: 2.0;
              defaultValue: -0.16;
              stepInterval: 0.01;
              displayName: "Wrap effect";
              aeDisplayName: "Wrap effect";
          parameter float twist
              minValue: -1.0;
              maxValue: 1.0;
              defaultValue: -0.08;
              stepInterval: 0.01;
              displayName: "Twist effect";
              aeDisplayName: "Twist effect";
          parameter float bulge
              minValue: -1.0;
              maxValue: 1.0;
              defaultValue: 0.0;
              stepInterval: 0.01;
              displayName: "Bulge effect";
              aeDisplayName: "Bulge effect";
          input image4 src;
          output pixel4 dst;
          void
          evaluatePixel()
              float2 hsize = size * 0.5;
              float2 rads = float2(PI / hsize.x, HALFPI / hsize.y);                // Radians per pixel
              float4 color = float4(0);
              float2 ps = float2(0);
              float rc = cos(radians(rotate));
              float rs = sin(radians(rotate));
              float2x2 rotation = float2x2(rc, rs, -rs, rc);
              #if DEBUG
              float3 guide = float3(0, 0, 0);
              float w = 0.05;
              #endif
                      float2 p = (outCoord() + ps - outputSize * 0.5 - center * outputSize) / size.y;
                      p *= rotation;
                      // Stereographic projection
                      float r = length(p);
                      float c = 2.0 * atan(r, 0.5 * (zoom + bulge));
                      float cc = cos(c);
                      float sc = sin(c);
                      float cl = cos(radians(latitude));
                      float sl = sin(radians(latitude));
                      float lat = asin(cc * sl + (p.y * sc * cl) / r) + (wrap * PI);
                      float lon = radians(longitude) + atan(p.x * sc, (r * cl*cc - p.y * sl * sc));
                      // Twist
                      lon += twist * r * PI;
                      // Wrap longitude
                      lon = mod(lon + PI, TWOPI) - PI;
                      if (wrap != 0.0) {
                          // Reflect the top and bottom to get smooth wrapping
                          if (lat > TWOPI) {
                              // Second inner sky reflection (+wrap)
                              #if DEBUG
                              if (lat < TWOPI + w) guide = float3(0, 1, 0);
                              #endif
                              lat = mod(abs(lat), HALFPI);
                          } else if (lat > TWOPI - HALFPI) {
                              // First inner sky reflection (+wrap)
                              #if DEBUG
                              if (lat < TWOPI - HALFPI + w) guide = float3(1, 0, 0);
                              #endif
                              lat = mod(abs(lat), HALFPI) - HALFPI;
                          } else if (lat > HALFPI) {
                              // First ground reflection (+wrap)
                              #if DEBUG
                              if (lat < HALFPI + w) guide = float3(0, 1, 0);
                              #endif
                              lat = PI - lat;
                          } else if (lat < -TWOPI) {
                              // Second outside sky reflection (-wrap)
                              #if DEBUG
                              if (lat > -TWOPI - w) guide = float3(0, 0, 1);
                              #endif
                              lat = -mod(abs(lat), HALFPI);
                          } else if (lat < -TWOPI + HALFPI) {
                              // Second outside ground reflection (-wrap)
                              #if DEBUG
                              if (lat > -TWOPI + HALFPI - w) guide = float3(0, 1, 1);
                              #endif
                              lat = HALFPI - mod(abs(lat), HALFPI);
                          } else if (lat < -PI) {
                              // First outside ground reflection (-wrap)
                              #if DEBUG
                              if (lat > -PI - w) guide = float3(0, 1, 0);
                              #endif
                          } else if (lat < -HALFPI) {
                              // First outside sky reflection (-wrap)
                              #if DEBUG
                              if (lat > -HALFPI - w) guide = float3(0, 0, 1);
                              #endif
                              lat = -HALFPI + mod(abs(lat), HALFPI);
                      // Convert back to equirectangular coordinates
                      float2 op = -float2(lon, lat) / rads;
                      op.y += bulge * r * hsize.x;
                      color += sampleLinear(src, clamp(hsize - op, float2(0.5), size - float2(0.5)));
                      #if DEBUG
                      if (guide != float3(0)) color.rgb += guide * 0.5;
                      #endif
              dst = color;
