3 Replies Latest reply: Oct 5, 2011 10:31 AM by JevgeniG RSS
    Sample : How to Installing AIR3 SDK in FlashDevelop 3 ?
    Porawee
      Hi everyone, if you not use Adobe Flash CS or Adobe FlashBuilder
      but you need to test AIR 3.0 SDK. I need to share sample that i try to other IDE as open source FlashDevelop.
      let's see below how to do that :
      ** For WIN version ONLY
      Requirement :
      1.     FlashDevelop 3.3.4 RTM  [recommend]
      2.     Flex SDK 4.5.0.19786 [recommend]
      3.     AIR 3.0 SDK
      Walkthrough this step :
           1. download and extract Flex SDK to "C:\flex_sdk_4.5.0.19786"
           2. download and extract AIR3.0 SDK to AIR3.0
           3. In folder AIR3.0 copy all file and paste in folder flex_sdk_4.5.0.19786.
           4. If you never install FlashDevelop just follow through it's installation,
                thenrun FlashDevelop goto "Project > New Project..."
           5. choose "AIR AS3 Projector"
           6. type your project name in text filed after "Name :"
           7. Browse.. "Location :" where you need to save your project, then click "OK"
           8. type your author name and click "OK",
                now your new project was created
           9. goto "Tools > Program Settings..."
           10. click "AS3Context" on left panel
           11. see on right panel click "Flex SDK Location"
           12. Browse.. to "C:\flex_sdk_4.5.0.19786"
           13. click "FlashViewer" on left panel
           14. see on right panel click "External Player Path"
           15. Browse.. to "C:\flex_sdk_4.5.0.19786\runtimes\player\10.2\win\FlashPlayerDebugger.exe", then click "Close"
           16. goto "Tools > Flash Tools > Documentation Generator..."
           17. goto tab "Settings"
           18. in text filed below "ASDoc location:"
           19. Browse.. to "C:\flex_sdk_4.5.0.19786\bin" , then click "Save Settings"
           20. see on right panel in FlashDevelop
                open file "CreateCertificate.bat"
                edit in line :
                     set PATH=%PATH%;$(FlexSDK)\bin
                change to
                     set PATH=%PATH%;C:\flex_sdk_4.5.0.19786\bin
           21. open file "PackageApplication.bat"
                edit in line :
                change to
           22. open file "Main.as" it's place inside folder src on right panel
                add this code to test your AIR runtime version
                import flash.desktop.NativeApplication;
                trace(NativeApplication.nativeApplication.runtimeVersion);
                Example :
                package
                    import flash.display.Sprite;
                     * @author Porawee Raksasin
                    public class Main extends Sprite
                        public function Main():void
           23. press F5, then you will see window adl and AIR window on screen as below :
           24. Finally, your output is...
                Done(0)
                [Starting debug session with FDB]
                3.0.0.3880
           Yeah! your app now ready for AIR 3.0.
      Hope you enjoy with AIR 3.0
      Porawee
