3 Replies Latest reply on Sep 28, 2011 9:45 PM by Mylenium
    Particle Playground -> Lifetime
    jahesscreen Level 1
      Hey guys,
      I have a layer with Particle Playground that shall emit an a texure (as another comp/layer).
      But after some seconds the textured particles are dying.
      I can`t find a lifetime parameter in particle playground settings.
      Is there a way to let those particles live forever?
      (AE CS4)
        • 1. Re: Particle Playground -> Lifetime
          You use one of the property mappers and color values of a layer to control opacity, size, or a bunch of other things relating to the particles. If you've used an effect to create your property map you must pre-compose. For example, create a new solid called ramp, add Effect>Generate>Ramp, precompose the Ramp layer moving all attributes, then select Persistent Property Mapper and choose Ramp Pre-comp as the source and map Red to Lifespan or to Opacity or Size.  Where your Ramp is black you get the minimum value, where it is white you get the Maximum Value.
          • 2. Re: Particle Playground -> Lifetime
            jahesscreen Level 1
            Hey Rick,
            i don`t want to fade the particles fromm 100% to 0%.
            All Particles have to live during the whole composition.
            example: flock of birds which have to fly through the pictures. My birds are dying after a certain time.
            I don`t like dead birds - but I havn`t an idea how to let them survive
            • 3. Re: Particle Playground -> Lifetime
              Well, you still have to use property maps to assign properties - a simple full size solid assigned to the lifespan parameter would do. Then simply crank up the relevant parameter in the persistent property mapper. I'm wondering, though. By default, Playground's particles live forever already, so there should be no need to do anything.
