1 Reply Latest reply on Jul 5, 2006 9:46 AM by Peter Grainge
    Authoring HTML for the Macintosh
      I need to write an HTML document to be used exclusively on the Macintosh running OS X 10.4 and higher. Is RoboHelp vX5 the right tool? I will be authoring on a PC.
      Thank you
        • 1. Authoring HTML for the Macintosh
          Sorry but I thought it better to warn you to test even though I do not have firm information. I do wish someone would run a little test, it would not take more than ten minutes and it sure would help.
          If you are able to run this test, please post back.
          UPDATE: On re-reading, I notice you say HTML document rather than a help output. Just using RH to generate an HTML document should be OK. The problem I refer to is with webhelp.
