5 Replies Latest reply on Oct 25, 2006 4:53 PM by
    Generating Webhelp issue
      When I generate my robohelp Web help, some htm files don't get generated correctly. When I check the original htm file it is correct, but the webhelp htm file has incorrect code in. What am I doing wrong? Thanks,
        • 1. Re: Generating Webhelp issue
          RoboWizard Level 4
          Hi MMQA and welcome to our community
          It would be really helpful if you could be more descriptive about exactly what you are seeing that you feel is incorrect.
          Cheers... Rick
          • 2. Re: Generating Webhelp issue
            Thanks, I have only been working with Robohelp for about a week now. So, just a beginner.
            What I can do is attach some screenshots (how do you attach some .png files??) of the original htm code and how it is displayed. Then also the web htm code and how it displays. Where I marked it on the screenshot, it seems to "corrupt" the code. I know how to fix the web htm manually, but the problem is the next time I generate the web files again, it stuffs it up again.
            • 3. Re: Generating Webhelp issue
              RoboWizard Level 4
              Hi again MMQA
              If you want to send the screen shots to my personal E-Mail address, that will work. Send to rstone75 AT kc DOT rr DOT com.
              I'll be happy to take a look at the pics and see if they make sense.
              Sincerely... Rick
              • 4. Re: Generating Webhelp issue
                RoboWizard Level 4
                Hi again
                Okay, got the pics. Thanks. What version of RoboHelp are you using? I see the WebHelp generation process appears to be inserting the image into a table? Actually, in looking a bit deeper, it would appear this topic was created using something other than RoboHelp HTML. Is that correct? If so, what exactly was used?
                Cheers... Rick
                • 5. Re: Generating Webhelp issue
                  The Robohelp Version I am using is Robohelp HTML 2002, Build949.
                  Most of the .htm files were created before my time here, but I think it was with Max's HTML Beauty++2004.
                  Do you know yet how I can get this fixed? Should I create a complete new one in Robohelp and edit there?
