0 Replies Latest reply on Sep 28, 2011 9:45 AM by Abhilash M
    Flex 4 with php error.
    Abhilash M
      Hi all, i'm connecting a flex application with database MySql, for that i'm using PHP as server side language. I followed a tutorial and created php class and tested. I'm getting the error at last step. This is what i did,
      1) create a php class name.php
      <?php
      * This sample service contains functions that illustrate typical
      * service operations. This code is for prototyping only.
      *  Authenticate users before allowing them to call these methods.
      class name {
        var $username = "root";
        var $password = "";
        var $server = "localhost";
        var $port = "3306";
        var $databasename = "test";
        var $tablename = "names";
        var $connection;
        public function __construct() {
          $this->connection = mysqli_connect(
                             $this->server,
                             $this->username,
                             $this->password,
                             $this->databasename,
                             $this->port
          $this->throwExceptionOnError($this->connection);
        public function getNames() {
           $stmt = mysqli_prepare($this->connection,
                "SELECT
                    names.firstname,
                    names.middlename,
                    names.lastname
                 FROM names");
            $this->throwExceptionOnError();
            mysqli_stmt_execute($stmt);
            $rows = array();
            mysqli_stmt_bind_result($stmt, $row->firstname, $row->middlename,
                          $row->lastname);
            while (mysqli_stmt_fetch($stmt)) {
                $rows[] = $row;
                $row = new stdClass();
                          $row->lastname);
            mysqli_stmt_free_result($stmt);
            mysqli_close($this->connection);
            return $rows;
         private function throwExceptionOnError($link = null) {
          if($link == null) {
            $link = $this->connection;
          if(mysqli_error($link)) {
            $msg = mysqli_errno($link) . ": " . mysqli_error($link);
            throw new Exception('MySQL Error - '. $msg);
      2)   Through data wizard, connect php and linked php class, it showed the methods and went to final step.
      3) Created a datagrid in flex, then dragged and droped getNames() to the datagid, then i configured return type. The datagrid then changed its fields to MySql table.
      4) Here was the problem, when i ran the application, it showed a error in this line,
      <fx:Script>
                          <![CDATA[
                                    import mx.controls.Alert;
                                    import mx.events.FlexEvent;
                                    protected function dataGrid_creationCompleteHandler(event:FlexEvent):void
                                              getNamesResult.token = name.getNames();
                </fx:Script>
      Error -
      DescriptionResourcePathLocationType
      1061: Call to a possibly undefined method getNames through a reference with static type String.flexphp.mxml/flexphp/srcline 13Flex Problem
      I'm new to flex, so wondering where exactly is the problem?
      I did traced back few steps, like followed Control+click on getNames(), but it took me to actionscript file and everything seemed perfect. Since you guys have experience, hope you would throw some light on error. Thanks!
