2 Replies Latest reply on Sep 29, 2011 12:37 AM by Venkatesan Balasubramanian
    how to add same name records from datagrid,while i am selecting one of the record and click add butt
    Venkatesan Balasubramanian Level 1
      hi  friends,
      i  am doing flex 4 mxml web application with as3,i am struck up in the following  concept,shar your suggession about this.
      i am using datagrid with 3 columns NUMBER, NAME, AMOUNT. one text box and one add button and one delete button.
      i have two records in the same name in grid, when i click one record from the grid and click ADD button means that time ,both records  AMOUNT WILL ADDED   which record having the same name and give that value in a text box.
      how to do this?
      any useful suggesssion or modal sample
      Thanks in advance,
      B.venkatesan.
        • 1. Re: how to add same name records from datagrid,while i am selecting one of the record and click add butt
          gajanan hiroji Level 1
          hello,
          var totalsum:int=0;
          var index:int=db.selectedindex;
          var selname:string =bd.dataprovide.getItemAt(index).name;
          var totallen:int=(db.dataprovider).length;
          for(var i:int=0;i<totallen;i++)
              var  checkduplicate:string=bd.dataprovide.getItemAt(i).name;
             if(checkduplicate==selname)
              totalsum+=bd.dataprovide.getItemAt(i).AMOUNT;
          textfield_id.text=totalsum
                               Gajanan Hiroji | hgajanan@isacweb.com | www.isacglobal.com
          • 2. Re: how to add same name records from datagrid,while i am selecting one of the record and click add butt
            hi gajanan hiroji,
            Thanks for the useful help.
            And one more think i want ask you, i am doing web application, i am using 5 modules in that,every module in a single page.
            In this application i am using datagrid in last 3 models. the operation is same for the models, select a record from grid then click post it should move to next page.
            In that i am writting init() function . this for showing the last module posted records here while i am entering this model.
            At the panel initializing time the records loading and showing in the gird,
            i written refresh function for this .
            But some times the function working properly and show the records in grid.
            some time it wont show the records.
            refresh function not working properly..
            looking for usful suggession,
            B.venkatesan.
