0 Replies Latest reply on Sep 29, 2011 9:04 AM by cortlander1
    Source path Flex config files not updated in generated output
    cortlander1
      I have a project, built using Flash Builder 4.0 on Mac OS X 10.6.
      One of my source directories is src/main/webapp which contains a WEB-INF directory with this structure:
      webapp
                - WEB-INF (applicationContext.xml etc)
                          - - classes
                          - - flex (services-config.xml, remoting-config.xml, proxy-config.xml, messaging-config.xml)
                          - - lib
      In properties, under Flex Build Path I have set src/main/webapp as an additional source folder.
      When the project compiles, all the artifacts are created, and all of the above, including *.xml files under
      WEB-INF are copied to the output folder, except for the WEB-INF flex directory which has the four xml
      configuration files.
      The same happens when I create a bin-release folder using the Project/Export Release Build menu.
      Any ideas why just the WEB-INF/flex directory is not being copied to bin-debug or bin-release?
      Thanks.
