14 Replies Latest reply on Jan 26, 2012 5:49 AM by Patook2132
    problem with writing a log file using writeln
    REVA83
      Hi All,
      Am writing script for InDesign CS5 and have problem with writing log file using writeln statement. Already i generate these kind of log file using with InDesign CS4.
      I am working with directory and there is collection of names and phone numbers. Yet I have to recieve some hundreds of phone number for the particular names. I want to collect those names and generate the log report. for example, John. K 000 000 00.
      Simply by using findGrep method, i found all the names and phone numbers which are having zeros. All these found items should be generated with one log file. I couldn't write the log using javascript "writeln" class. But I can alert and show all the found names and zeros. Simply i can write some text, and those texts are written in log file. But these things are not write in the log file and i couldn't generate the report.
      If anyone already faced and have a solution for this, please provide your valuable suggestion and ideas.
      Many thanks
      Peru.
        • 1. Re: problem with writing a log file using writeln
          csm_phil Level 4
          Hi Peru,
          Please try this below JS Code.
          var myDocname  =  myDoc.name
          var Report = new File("~/Desktop/Indd_Report.log" );
          Report .open( "w" );
          // here i write the file name only in log file,  You already alert the text, just you replace the below (myDocname) instead of you finding result.
          Report.writeln(myDocname);
          Report.close();
          thx
          csm_phil
          • 2. Re: problem with writing a log file using writeln
            REVA83 Level 1
            Hi csm_phil,
            Thanks for your reply. The same thing only i have been used in my code. Please see below.
            I can alert and show the found items. But, the generated log file is empty. That is what my problem.
            Pleas look into the Javascript console. I have written the "myLogFile.writeln("  "+serialno+".  "+myFound[k]);". The result is false. That is why the report generated with only one line which is "Yet to be updated phone numbers" in 14 th line of my code. But if i select in the console only the line ("  "+serialno+".  "+myFound[k]);, which give the output correctly. Also sequentially i can show the output exactly in the console. But i couldn't see in the report in the generated log file.
            Please advice.
            • 3. Re: problem with writing a log file using writeln
              csm_phil Level 4
              Hi Peru,
              Please try this JS code i have modified your JS code. Its working fine to me.
              app.findGrepPreferences = app.changeGrepPreferences = null;
              app.findGrepPreferences.findWhat = "\\b(\\w.+\\s000\\s000\\s00)";
              var mySearch = myDoc.findGrep();
              for (var i =0; i<mySearch.length; i++){
                  Report.writeln(mySearch[i].contents);
              Report.close();
              alert("Done!");
              thx
              csm_phil
              • 4. Re: problem with writing a log file using writeln
                John Hawkinson Level 5
                THat's weird. I don't suppose it will help, but please put semicolons (;) at the end of your JavaScript lines and try again.
                • 5. Re: problem with writing a log file using writeln
                  REVA83 Level 1
                  Hello John,
                  Am always using semicolons at end of the JavaScript lines, also checked once again and tried. Eventhough I couldn't get the generated report.
                  Any other suggestion would be helpful.
                  Many thanks
                  Peru.
                  • 6. Re: problem with writing a log file using writeln
                    csm_phil Level 4
                    Hi Peru,
                    Have you tried my previous post JS Code is working fine in my system. Please use that and revert.
                    thx
                    csm_phil
                    • 7. Re: problem with writing a log file using writeln
                      REVA83 Level 1
                      Hi csm_phil,
                      Yes. I tried your code in both CS5 and CS4. But i got only the empty report as usual. If i alert, i can see all the searched contents. But its not written inside the log file.
                      This might be any system related problem? I am using the Mac OS 10.5.2. InDesign CS5 7.0.
                      Please suggest anyone.
                      Thank you all
                      • 8. Re: problem with writing a log file using writeln
                        Manan Joshi Level 4
                        Hello Peru,
                        The code written by csm_phil should work, could you make sure that you have all the rights on the location where you are trying to create the log file and that the path you are using is correct.
                        I mean we need to be sure first that the file is being created. You can use a simple script like
                        var logFile = new File("~/Desktop/Report.log");
                        logFile.open("w");
                        logFile.writeln("Hello");
                        and see if it works or not, if not then what is the status, the file is created but not written or not created at all. You can try out by using a different path to save the log file.
                        I am using MAC 10.6.8 and the above code works both for CS4 and CS5.
                        Try this and let us know.
                        Manan Joshi
                        - Efficient InDesign Solutions -
                        MetaDesign Solutions
                        http://metadesignsolutions.com/services/indesign-development.php
                        • 9. Re: problem with writing a log file using writeln
                          REVA83 Level 1
                          Hi Manan,
                          I don't have any problem with creating .log file. My real problem is inside the log file, there is no text to be generated.
                          Please look into my post dated Sep 29, 2011 10:27AM. I am able to create a .log file. Alos have a look at the Javascript console. I have written the "myLogFile.writeln("  "+serialno+".  "+myFound[k]);". The result is false. That is why the report generated without any output text. If I alert myFound, i can show all the output what i want. But i couldn't see the "myFound" contents in the generated log file.
                          Manan, need more explanation regarding my problem, please let me know.
                          Any other suggestion would be helpful for me to write the myFound in my log report.
                          Thanks for all
                          Regards
                          Peru.
                          • 10. Re: problem with writing a log file using writeln
                            Manan Joshi Level 4
                            Peru,
                            Did you try out with my peice of code, i means lets keep the code simple and just try to write a file. You could also try trashing your preferences and then run the code.
                            Manan
                            • 11. Re: problem with writing a log file using writeln
                              csm_phil Level 4
                              Hi Peru,
                              Can you please post the full JS code?
                              thx
                              csm_phil
                              • 12. Re: problem with writing a log file using writeln
                                REVA83 Level 1
                                Hi csm_phil,
                                Please find below as my code.
                                var myDocPath = myDoc.filePath;
                                var myDocName = myDoc.name;
                                var myFound = new Array()
                                for (var j = 0; j < mySearch.length; j++)
                                myFound.push (mySearch[j].contents);
                                alert(myFound);
                                var inc=0;
                                var myLogFile = new File(myDocPath.fsName + "/Report_" + myDocName.split(".")[0] +".log");
                                if(myLogFile.open("w", undefined, undefined))
                                myLogFile.writeln("Tool name : Report Generator for CS5");
                                myLogFile.writeln("************************************");
                                if(myFound.length != 0)
                                        myLogFile.writeln("");
                                        for (var k = 0; k<myFound.length; k++)
                                   serialno = k + 1;
                                  else
                                   myLogFile.writeln("No terms found");
                                //myDoc.close();
                                The above two bolded lines only generated in my report. Please check and let me know, if there need any modification to generate the report with myFound Array also.
                                Many thanks
                                Peru.
                                • 13. Re: problem with writing a log file using writeln
                                  csm_phil Level 4
                                  Hi Peru,
                                  I have checked the above mentioned JS Code is working fine in my MAC system 10.5.6 version.
                                  Can you please try save the InDesign document  in  system local (i.e, Desktop or D:)  and try again, I think you open the InDesign file in direct from the server don't try this for now testing stage.
                                  Please try and let me know please find the attached report also.
                                    1.  This is for test coding InDesign. K 000 000 00
                                    2.  This is for test John. K 000 000 00
                                  thx
                                  csm_phil
                                  • 14. Re: problem with writing a log file using writeln
                                    Patook2132
                                    Perhaps the string used with writeln is an UTF-8 string and your file was opened with an other encoding ?
                                    Try to use : file.encoding="UTF-8";
