1. Re: Getting data from SQL database
John Hawkinson Sep 30, 2011 10:41 PM (in response to Roy Marshall)Hmm, the dangers of answering threads in reverse chronological order. Apparently you are familiar with the Socket api.
Something like that should work, yes.
But your question is quite oddly phrased. I assume you've tried that and it does not work [else why would you be posting]? But you do not tell us how it fails!
How does it fail?
2. Re: Getting data from SQL database
Roy Marshall Oct 2, 2011 3:26 AM (in response to John Hawkinson)Hi.
I have spent some time playing with the code below:
reply = "";
conn = new Socket();
conn.open("localhost:80");
conn.write(" GET /getassetstatus.php?enc=10.1.1.234~38~11~13446~PASSWORD");
reply = conn.read(999999);
conn.close;
where the php file on my computer "getassetstatus.php" takes the string, and returns a number. This works when being passed as a curl commend 2 layers deep inside doScript, but I want to take out the Applescript dependancy.
I dont know what the "GET" does, and the code I used as a base had "HTTP/1.0\n\n" at the end of the url.
With all my tests, the variable reply is always empty.
If anyone can help, I would be grateful.
Cheers
Roy
3. Re: Getting data from SQL database
John Hawkinson Oct 2, 2011 5:37 AM (in response to Roy Marshall)conn.write(" GET /getassetstatus.php?enc=10.1.1.234~38~11~13446~PASSWORD");
You need the <SPACE>HTTP/1.0\n\n! Why did you take it out? Check the protocol spec, http://www.ietf.org/rfc/rfc2616.txt.
You also have a leading space that looks wrong. So:
conn.write("GET /getassetstatus.php?enc=10.1.1.234~38~11~13446~PASSWORD HTTP/1.0\n\n") -
4. Re: Getting data from SQL database
Roy Marshall Oct 2, 2011 10:25 AM (in response to John Hawkinson)HI.
I did an attempt with the missing code previously, and several other variations. All not giving me the single value I was expecting back.
What I do get however is this
HTTP/1.1 200 OK Date: Sun, 02 Oct 2011 17:21:01 GMT Server: Apache/2.2.17 (Unix) mod_ssl/2.2.17 OpenSSL/0.9.8r DAV/2 PHP/5.3.4 X-Powered-By: PHP/5.3.4 Content-Length: 1 Connection: close Content-Type: text/html 2
Only now I realize that this IS correct, as the number I was wanting is the 2 at the end!
DOH!
Thnaks agaoin John, jou have been most helpful and patient.
5. Re: Getting data from SQL database
John Hawkinson Oct 2, 2011 12:02 PM (in response to Roy Marshall)Sigh...
I'm sorry, Roy, I really thought that the example in the JS Tools Guide told you how to seperate the actual response from the server's headers. But it doesn't!
Anyhow, RFC2616 tells us:
6 Response
After receiving and interpreting a request message, a server responds
with an HTTP response message.
Response = Status-Line ; Section 6.1
*(( general-header ; Section 4.5
| response-header ; Section 6.2
| entity-header ) CRLF) ; Section 7.1
CRLF
[ message-body ] ; Section 7.2
So, that means the message body is seperated by two CRLF pairs. Except that because of API magic each CRLF turns into a single \n. So you want to look for \n\n.
So, you should be able to seperate it like this:
body = reply.substr(reply.indexOf("\n\n")+2); -
6. Re: Getting data from SQL database
Roy Marshall Oct 2, 2011 1:07 PM (in response to John Hawkinson)Cheers John
I have the "javascript tools guide cs3" but dont seem to have the CS5 version. Do you know where I can get it?
Anyway, I didn't think to look in this document, I actually forgot about it, but I will try to familiarise myself with this.
Out of interest I used
myDataToUse = reply[reply.length-1];
As I am only interested in a single digit!
Thanks Again.
Roy
7. Re: Getting data from SQL database
Harbs. Oct 2, 2011 1:49 PM (in response to Roy Marshall)It should be available for the help menu in the ESTK.
Harbs
8. Re: Getting data from SQL database
John Hawkinson Oct 2, 2011 2:40 PM (in response to Roy Marshall)I have the "javascript tools guide cs3" but dont seem to have the CS5 version. Do you know where I can get it?
Harbs is certainly right, but you should bookmark the Adobe InDesign Scripting Resources page.
But it links to http://wwwimages.adobe.com/www.adobe.com/content/dam/Adobe/en/products/indesign/pdfs/JavaS criptToolsGuide_CS5.pdf.
You realize this is a bad idea...what if it goes to ten? Or if you try to repurpose the code for something else? Etc.
9. Re: Getting data from SQL database
Roy Marshall Oct 2, 2011 2:47 PM (in response to John Hawkinson)Yeah, I realise this, but for this one use, I will only ever be looking for a number indicating a status, that will always only be 1, 2 or 3.
I hear what you are saying though, and will bear in mind in the future.
Cheers
Roy
10. Re: Getting data from SQL database
Roy Marshall Oct 3, 2011 2:07 AM (in response to John Hawkinson)One more quick question, I want to use this same method to pass a log entry to a PHP page which I have been doing up to now with the doscript.
I have tried the same technique:
conn.write("GET /sendSrcError.php?e=" + errorText+" HTTP/1.0\n\n"); but nothing is being written by the php. I am not trying to get anything back, just posting, so maybe a different metod is needed.
Can you advise here?
Cheers
Roy
11. Re: Getting data from SQL database
John Hawkinson Oct 4, 2011 9:08 PM (in response to Roy Marshall)Sorry I missed your question yesterday, Roy.
Are you trying to send a second query in the same connection as the first? Try a seperate connection.
What is "errorText" Can it contain spaces? Please $.writln() out the exact text being sent and post it here...
12. Re: Getting data from SQL database
Roy Marshall Oct 5, 2011 2:44 PM (in response to John Hawkinson)The text I am passing has been through an encodeURI so all spaces etc are web valid.
I will send the complete line when I can...
13. Re: Getting data from SQL database
John Hawkinson Oct 5, 2011 9:19 PM (in response to Roy Marshall)I am standing by for the complete line. But are you re-using the same connection, yes or no?
14. Re: Getting data from SQL database
Roy Marshall Oct 6, 2011 10:57 AM (in response to John Hawkinson)Hi John.
No, its a new connection, in a totally different function.
myServerAddress = "automation.yappp.net:80"; conn = new Socket();
conn.open(myServerAddress);
conn.close;
and this is the old code using the curl...
myFullScriptString = "do shell script \"curl -0 "+ myServerAddress + "sendSrcError.php?e=" + errorText + "\"";
This works perfect.
I am sure it is something small I am doing wrong...
15. Re: Getting data from SQL database
John Hawkinson Oct 6, 2011 12:00 PM (in response to Roy Marshall)As I said, please $.writeln() the complete line being sent and post it here.
16. Re: Getting data from SQL database
John Hawkinson Oct 6, 2011 12:02 PM (in response to Roy Marshall)Err, this code can't be write:
myServerAddress = "automation.yappp.net:80"; myFullScriptString = "do shell script \"curl -0 "+ myServerAddress + "sendSrcError.php?e=" + errorText + "\"";
This works perfect.
Because it would give you "curl -O automation.yappp.net:80sendSrcError.php?e=something" with no slash before sendSrcError.
Care to clarify?
17. Re: Getting data from SQL database
Roy Marshall Oct 6, 2011 12:56 PM (in response to John Hawkinson)Yes, but as I said, they are 2 separate functions, and I didn't copy the server address in to my last post for the curl. Sorry to mislead...
myServerAddress = "http://automation.yappp.net/"; also, I am a total newby to this part of Javascript, I have only been living purely in InDesign, and not ventured out into the web side till now. I dont even know HTML to my shame!
Please can you clarify what you mean by this?
If you dont get to reply, I will talk to my son tonight who will tell me how to do what you are asking, and i will post what you are asking!
Sorry, but I am not going to pretend to know anything I dont know!
18. Re: Getting data from SQL database
Roy Marshall Oct 7, 2011 2:20 AM (in response to Roy Marshall)Can you explain in more detail what you are asking?
19. Re: Getting data from SQL database
Roy Marshall Oct 7, 2011 2:44 AM (in response to Roy Marshall)As I am showing my ignorance in not knowing what you are asking, here are the 2 functions. One works, and the other not.
This Does not post anything.
function combinedErrorReportWithSocket(errorText) //errorText is something like "Library not found"
errorText = encodeURI(errorText);
conn.write("GET /sendSrcError.php?e=" + errorText+"\ HTTP/1.0\n\n");
conn.close;
This works OK, and adds a line at the top of the web page.
function combinedErrorReport(errorText) //errorText is something like "Library not found"
myForceError = app.doScript(myFullScriptString, ScriptLanguage.APPLESCRIPT_LANGUAGE);
go to http://automation.yappp.net/sendSrcError.php?p=logs to see the logs being logged.
Feel free to add some entries.
20. Re: Getting data from SQL database
SuperMacGuy Oct 7, 2011 8:32 AM (in response to Roy Marshall)I don't want to muddy things up, but if you want some other options for OSX, I've been using some scripts and frameworks to talk to an MS-SQL db, and it should work for some other SQL db's also. Send me a PM if interested.
21. Re: Getting data from SQL database
John Hawkinson Oct 7, 2011 8:36 AM (in response to Roy Marshall)Sorry about that!
Sure! I wasn't trying to be cryptic, and I guess I missed your first request for clarification.
We want to know exactly what is being sent to the server, so we can understand what might be wrong.
So, just add this line beforehand:
$.writeln("SENDING: <<"+"GET /sendSrcError.php?e=" + errorText+"\ HTTP/1.0\n\n"+">>"); Conn.write("GET /sendSrcError.php?e=" + errorText+"\ HTTP/1.0\n\n");Then it will print the GET line on the console and you can paste it here and we can see what (if anything) is wrong with it.
22. Re: Getting data from SQL database
Roy Marshall Oct 7, 2011 11:29 AM (in response to John Hawkinson)Hi John.
I have done that (Thanks for the instructions)
Here is the result:
SENDING: <<GET /sendSrcError.php?e=text%20To%20Send HTTP/1.0
Roy
23. Re: Getting data from SQL database
Roy Marshall Oct 10, 2011 12:06 PM (in response to Roy Marshall)This question is being continued in http://forums.adobe.com/message/3963484#3963484
24. Re: Getting data from SQL database
John Hawkinson Oct 10, 2011 6:20 PM (in response to Roy Marshall)Sorry for the delay, I was gone for the long weekend.
I should also have asked you, as part of the diagnostic process, to tell us what was in reply.
I don't know about other people, but I find that practice annoying. Stick with your thread, don't try to bump it. IMNSHO.
Anyhow, the problem appears to be that your server does not accept HTTP/1.0 queries in this case, it requires HTTP/1.1. I am not sure why that would be it seems surprising to me.
So, you should restructure your code like this, to be HTTP/1.1 compliant, which basically means including the Host: header to support HTTP/1.1 Virtual Hosting:
function combinedErrorReportWithSocket(errorText) //errorText is something like "Library not found" { myServer = "automation.yappp.net"; myPort=80; myServerAddress=myServer+myPort; errorText = encodeURI(errorText); conn = new Socket(); conn.open(myServerAddress); conn.write("GET /sendSrcError.php?e=" + errorText+ " HTTP/1.1\nHost: "+myServer+"\n\n"); reply = conn.read(999999); conn.close; } -
25. Re: Getting data from SQL database
John Hawkinson Oct 10, 2011 6:54 PM (in response to John Hawkinson)Whoops, typo. Left out the colon, should be:
myServerAddress=myServer+":"+myPort;
26. Re: Getting data from SQL database
Roy Marshall Oct 10, 2011 7:01 PM (in response to John Hawkinson)Hi John.
Thats perfect.
I have been feeling so frustrated with this up to now. I wont pretend to understand the solution, maybe in time I will, but I am a happy bunny now.
Thanks again,
Roy
27. Re: Getting data from SQL database
Dr. TYPO Sep 25, 2014 7:27 AM (in response to Roy Marshall)hi all,
just wanted to reactivate this topic as we've proudly released an innovation: http://www.porky.io
porky is a ESTK/JavaScript extension/functions library and you can use various data types like SQL databases, XML- and JSON files as a variable source.
So: create entire publishing workflows based on your JavaScript code!
Happy coding :-)
Cheers
28. Re: Getting data from SQL database
csparrowsugoi Oct 8, 2014 11:05 AM (in response to Dr. TYPO)HI Dr. TYPO
I'm interested in your innovation and downloaded/installed it, but when i follow the instructions and double click the "start-porky-data-source-access.jsx" as it states I get a warning that says "not yet implemented, sorry"
I am using CC, would that be the issue?
Nevermind, looked at the code and noticed it was applescript. Do you have a PC workaround?
29. Re: Getting data from SQL database
Dr. TYPO Oct 8, 2014 12:57 PM (in response to csparrowsugoi)Thanks for your interest in porky!
On OS-X we have a php interpreter (which handles the database connection) already included out of the box.
The launcher script for the windows platform will be implemented pretty soon – I'll let you know as soon as it is ready!
30. Re: Getting data from SQL database
Dr. TYPO Oct 24, 2014 8:39 AM (in response to csparrowsugoi)Hi csparrowsugoi,
the Windows version of porky (JavaScript library with database access for Adobe InDesign) is now available!
Please check porky.io and follow the installation guide in the download section.
Cheers
31. Re: Getting data from SQL database
Sugoi Art Dept Oct 24, 2014 8:58 AM (in response to Dr. TYPO)thank you kindly sir. I'll check it out! Hopefully I'm smart enough to get by installation lol
32. Re: Getting data from SQL database
Sugoi Art Dept Oct 24, 2014 9:31 AM (in response to Dr. TYPO)Amazing.. works like a charm. I think I can easily work this for a direct to mySQL connection using the SQLLite examples. Kudos!
