2 Replies Latest reply: Sep 30, 2011 9:13 PM by donraffaele RSS
    can't install Adobe Air in win 7 Ultimate
    donraffaele Community Member
      Hi all some help would be great here woke up this morning to find error messages after an update seems to be associated with Adobe Air keep getting this when i try to install adobe air
      An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator.
      i have tried all sorts of fixes with no help,I", not even able to uninstall Air .Help Please
        • 1. Re: can't install Adobe Air in win 7 Ultimate
          chris.campbell Employee Hosts
          I'm sorry you're running into this.  Could you post the contents of your AIR installer log?
          AIR Installer Log Instructions
          Chris
          • 2. Re: can't install Adobe Air in win 7 Ultimate
            Thanks Chris for the help ,here is the log file
            [2011-09-30:19:15:57] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:19:15:57] Commandline is:
            [2011-09-30:19:15:57] No installed runtime detected
            [2011-09-30:19:16:00] Relaunching with elevation
            [2011-09-30:19:16:00] Launching subprocess with commandline c:\users\don\appdata\local\temp\airf90f.tmp\adobe air installer.exe -ei
            [2011-09-30:19:16:03] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:19:16:03] Commandline is: -stdio \\.\pipe\AIR_7332_0 -ei
            [2011-09-30:19:16:03] No installed runtime detected
            [2011-09-30:19:16:03] Starting silent runtime install. Installing runtime version 2.7.1.19610
            [2011-09-30:19:16:03] Installing msi at c:\users\don\appdata\local\temp\airf90f.tmp\setup.msi with guid {FDB3B167-F4FA-461D-976F-286304A57B2A}
            [2011-09-30:19:16:03] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:19:16:03] Rolling back install of c:\users\don\appdata\local\temp\airf90f.tmp\setup.msi
            [2011-09-30:19:16:03] Rollback complete
            [2011-09-30:19:16:03] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:19:16:03] Runtime Installer end with exit code 7
            [2011-09-30:19:16:07] Runtime Installer end with exit code 7
            [2011-09-30:19:53:30] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:19:53:30] Commandline is:
            [2011-09-30:19:53:30] No installed runtime detected
            [2011-09-30:19:53:38] Relaunching with elevation
            [2011-09-30:19:53:38] Launching subprocess with commandline c:\users\don\appdata\local\temp\air18cd.tmp\adobe air installer.exe -ei
            [2011-09-30:19:53:41] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:19:53:41] Commandline is: -stdio \\.\pipe\AIR_1596_0 -ei
            [2011-09-30:19:53:41] No installed runtime detected
            [2011-09-30:19:53:41] Starting silent runtime install. Installing runtime version 2.7.1.19610
            [2011-09-30:19:53:41] Installing msi at c:\users\don\appdata\local\temp\air18cd.tmp\setup.msi with guid {FDB3B167-F4FA-461D-976F-286304A57B2A}
            [2011-09-30:19:53:41] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:19:53:41] Rolling back install of c:\users\don\appdata\local\temp\air18cd.tmp\setup.msi
            [2011-09-30:19:53:41] Rollback complete
            [2011-09-30:19:53:41] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:19:53:41] Runtime Installer end with exit code 7
            [2011-09-30:19:53:50] Runtime Installer end with exit code 7
            [2011-09-30:20:25:59] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:20:25:59] Commandline is:
            [2011-09-30:20:25:59] No installed runtime detected
            [2011-09-30:20:26:20] Relaunching with elevation
            [2011-09-30:20:26:20] Launching subprocess with commandline c:\users\don\appdata\local\temp\aire7fe.tmp\adobe air installer.exe -ei
            [2011-09-30:20:26:22] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:20:26:22] Commandline is: -stdio \\.\pipe\AIR_1868_0 -ei
            [2011-09-30:20:26:22] No installed runtime detected
            [2011-09-30:20:26:22] Starting silent runtime install. Installing runtime version 2.7.1.19610
            [2011-09-30:20:26:22] Installing msi at c:\users\don\appdata\local\temp\aire7fe.tmp\setup.msi with guid {FDB3B167-F4FA-461D-976F-286304A57B2A}
            [2011-09-30:20:26:22] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:20:26:22] Rolling back install of c:\users\don\appdata\local\temp\aire7fe.tmp\setup.msi
            [2011-09-30:20:26:22] Rollback complete
            [2011-09-30:20:26:22] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:20:26:22] Runtime Installer end with exit code 7
            [2011-09-30:20:26:27] Runtime Installer end with exit code 7
            [2011-09-30:20:28:26] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:20:28:26] Commandline is:
            [2011-09-30:20:28:26] No installed runtime detected
            [2011-09-30:20:28:34] Relaunching with elevation
            [2011-09-30:20:28:34] Launching subprocess with commandline c:\users\don\appdata\local\temp\air2952.tmp\adobe air installer.exe -ei
            [2011-09-30:20:28:39] Elevated install failed: returned error code -1
            [2011-09-30:20:28:39] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Launching elevated sub-installer failed" errorID=5100]
            [2011-09-30:20:28:52] Runtime Installer end with exit code 7
            [2011-09-30:21:00:43] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:21:00:43] Commandline is:
            [2011-09-30:21:00:43] No installed runtime detected
            [2011-09-30:21:00:47] Relaunching with elevation
            [2011-09-30:21:00:47] Launching subprocess with commandline c:\users\don\appdata\local\temp\airb54c.tmp\adobe air installer.exe -ei
            [2011-09-30:21:00:49] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:21:00:49] Commandline is: -stdio \\.\pipe\AIR_4264_0 -ei
            [2011-09-30:21:00:49] No installed runtime detected
            [2011-09-30:21:00:50] Starting silent runtime install. Installing runtime version 2.7.1.19610
            [2011-09-30:21:00:50] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:21:00:50] Rolling back install of c:\users\don\appdata\local\temp\airb54c.tmp\setup.msi
            [2011-09-30:21:00:50] Rollback complete
            [2011-09-30:21:00:50] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:21:00:50] Runtime Installer end with exit code 7
            [2011-09-30:21:00:51] Runtime Installer end with exit code 7
            [2011-09-30:21:02:31] Runtime Installer begin with version 2.7.1.19610 on Windows Vista x86
            [2011-09-30:21:02:31] Commandline is:
            [2011-09-30:21:02:31] No installed runtime detected
            [2011-09-30:21:02:35] Relaunching with elevation
            [2011-09-30:21:02:35] Launching subprocess with commandline c:\users\don\appdata\local\temp\air5b89.tmp\adobe air installer.exe -ei
            [2011-09-30:21:02:38] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:21:02:38] Commandline is: -stdio \\.\pipe\AIR_5364_0 -ei
            [2011-09-30:21:02:38] No installed runtime detected
            [2011-09-30:21:02:39] Installing msi at c:\users\don\appdata\local\temp\air5b89.tmp\setup.msi with guid {FDB3B167-F4FA-461D-976F-286304A57B2A}
            [2011-09-30:21:02:40] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:21:02:40] Rolling back install of c:\users\don\appdata\local\temp\air5b89.tmp\setup.msi
            [2011-09-30:21:02:40] Rollback complete
            [2011-09-30:21:02:40] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:21:02:40] Runtime Installer end with exit code 7
            [2011-09-30:21:02:58] Runtime Installer end with exit code 7
            [2011-09-30:21:03:20] Runtime Installer begin with version 2.7.1.19610 on Windows Vista x86
            [2011-09-30:21:03:20] Commandline is:
            [2011-09-30:21:03:20] No installed runtime detected
            [2011-09-30:21:03:31] Relaunching with elevation
            [2011-09-30:21:03:31] Launching subprocess with commandline c:\users\don\appdata\local\temp\air1b6d.tmp\adobe air installer.exe -ei
            [2011-09-30:21:03:31] Runtime Installer begin with version 2.7.1.19610 on Windows Vista x86
            [2011-09-30:21:03:31] Commandline is: -stdio \\.\pipe\AIR_6684_0 -ei
            [2011-09-30:21:03:31] No installed runtime detected
            [2011-09-30:21:03:31] Installing msi at c:\users\don\appdata\local\temp\air1b6d.tmp\setup.msi with guid {FDB3B167-F4FA-461D-976F-286304A57B2A}
            [2011-09-30:21:03:32] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:21:03:32] Rolling back install of c:\users\don\appdata\local\temp\air1b6d.tmp\setup.msi
            [2011-09-30:21:03:32] Rollback complete
            [2011-09-30:21:03:32] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:21:03:32] Runtime Installer end with exit code 7
            [2011-09-30:21:03:33] Runtime Installer end with exit code 7
            [2011-09-30:22:57:43] Runtime Installer begin with version 2.7.1.19610 on Windows Vista x86
            [2011-09-30:22:57:43] Commandline is:
            [2011-09-30:22:57:43] No installed runtime detected
            [2011-09-30:22:57:53] Relaunching with elevation
            [2011-09-30:22:57:53] Launching subprocess with commandline c:\users\don\appdata\local\temp\air79f0.tmp\adobe air installer.exe -ei
            [2011-09-30:22:57:55] Runtime Installer begin with version 2.7.1.19610 on Windows 7 x86
            [2011-09-30:22:57:55] Commandline is: -stdio \\.\pipe\AIR_3572_0 -ei
            [2011-09-30:22:57:55] No installed runtime detected
            [2011-09-30:22:57:55] Starting silent runtime install. Installing runtime version 2.7.1.19610
            [2011-09-30:22:57:55] Installing msi at c:\users\don\appdata\local\temp\air79f0.tmp\setup.msi with guid {FDB3B167-F4FA-461D-976F-286304A57B2A}
            [2011-09-30:22:57:55] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:22:57:55] Rolling back install of c:\users\don\appdata\local\temp\air79f0.tmp\setup.msi
            [2011-09-30:22:57:55] Rollback complete
            [2011-09-30:22:57:55] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1612" errorID=0]
            [2011-09-30:22:57:55] Runtime Installer end with exit code 7
            [2011-09-30:22:57:56] Runtime Installer end with exit code 7
