4 Replies Latest reply on Oct 1, 2011 12:46 PM by Paul Ciotti2
    Why can't I delete gaps in the video or audio timeline?
    Paul Ciotti2
      I have added narration to a sequence of old (silent) video clips. But when I delete or add a clip to march the narration I frequently get a gap on either the video line or the narration line. I can click on it to turn it gray but I can't delete to close the gap. The audio and video are not linked. They were recorded at totally different times. Why can't I click on a grayed gap and delete this?
      One note:every once in a while (one time in ten) I can delete a grayed area. I have no idea what I've done on this occasion to close gaps.
      Any suggestions?
        • 1. Re: Why can't I delete gaps in the video or audio timeline?
          It all depends on if there are video or audio clips on parallel tracks that are keeping it from being a true "gap".
          • 2. Re: Why can't I delete gaps in the video or audio timeline?
            Paul Ciotti2 Level 1
            Steve
            I'm not sure I understand. What is the difference between a true gap and and an apparent gap? There were no gaps in either the narrative or the video until I inserted (or deleted a clip). I'm only using one track (the first one). And I've added the narrative just below it. There is nothing at all on video 2 or audio 2 (except for the title at the very beginning).
            How do other people add a short clip into the video 1 timeline without introducing a comparable gap in the narrative line below?
            This is maddening when I'm trying to finish what is really only a 12 minute video. Attempting to close everything back up again literally stops me cold. I assume more sophisticated users have ways of dealing with  this. I wish I knew what they were.
            best wishes
            Paul
            • 3. Re: Why can't I delete gaps in the video or audio timeline?
              If you will post a screen capture of your timeline with all of your video and audio tracks displayed, we can easily tell you which gaps are true gaps and which gaps will not delete-and-close because of video or audio on parallel tracks.
              • 4. Re: Why can't I delete gaps in the video or audio timeline?
                Steve
                Here is an example of a non-deletable gap that opened when I deleted a
                short video clip. As you can see (except for the title) I'm only using
                video1 and audio1. The audio track on audio 1 was not created at the
                same time as any of the video clips so they shouldn't be linked in any
                way. I made the audio track on my video camera (which has excellent
                sound quality) and imported it and put it under the video clips. What I
                don't understand is why, when I delete a clip, the rest of the files to
                the right just don't move over and close the gap. To close these gaps
                manually has been a bit of an ordeal because I have to move over every
                clip to the right of the gap. Or perhaps you know of an easy way to do this.
                best
                Paul
