11 Replies Latest reply on Oct 3, 2011 7:45 AM by 3n31h3m
    CS5 ... can't crop
    Chuckmg
      All of a sudden I can not crop an image. ???  Any help?
        • 1. Re: CS5 ... can't crop
          Silkrooster Adobe Community Professional & MVP
          How are you accessing the crop tool, using the icon in the tool bar or the keyboard shortcut? What happens when you try it? What version of photoshop do you have? What system are you using? What version of OS are you using? Could you post some screen shots of what is happening?
          Your short and sweet post doesn't really cut it does it? That was meant as a kind of joke, but I hope you see my point.
          • 2. Re: CS5 ... can't crop
            Chuckmg Level 1
            >created by <http://forums.adobe.com/people/Silkrooster>Silkrooster
            >in Photoshop Windows -
            ><http://forums.adobe.com/message/3948332#3948332>View the full
            >discussion
            >happening?
            In answer to your questions:
            1.  Win7 x64  SP 1 ... no version number to be found (??)
            2. Photoshop   v. 12.0.4 x64
            3.  Screen shots attached
            Observations
            a.  'C'  brings up Crop Tool
            b.  Image > Crop needs to have object selected  as usual
            c.  Can't escape Crop  by hitting Escape or Return  buttons.
            d.  It is not a Smart Layer
            As you can see,  Crop  starts out where expected ...  but that's it!
            Sorry about that .    You are right unless the answer is obvious!
            I recently switched from WinXP  to Win7  and had a similar problem
            (with something else).  I documented the problem and system at  great
            length.  I received a very short reply with regard to a new switch.
            My lengthy documentation was  totally unnecessary.   Hence if this
            were something equally  obvious and trivial, I didn't want to waste a
            lot of time documenting  it.   I am a retired professional.
            If it weren't obvious to you,  I was looking for your guidance.  You
            gave it to me ... and here are some screen shots.
            Observations
            Chuck
            • 3. Re: CS5 ... can't crop
              Noel Carboni Level 8
              None made it to the forum.
              Please use the web interface to upload images.
              -Noel
              • 5. Re: CS5 ... can't crop
                Once you've got the crop region as you see it in the second image, if you click the checkmark at the top of the Photoshop main window to complete the crop, what happens?  Does the X work to abort the crop?
                -Noel
                • 6. Re: CS5 ... can't crop
                  Chuckmg Level 1
                  >crop?
                  This can get very frustrating, n'est pas!!
                  1. ...  if you click the checkmark at the top of the Photoshop main
                  Some times it is an undo, and some times it completes the crop.  In
                  the former case, the Copy tool  (CT) nodes are still there and
                  usually cannot be dismissed by esc or CR.
                  2. Does the X work to abort the crop?
                  What is X??     If you mean  esc,  on rare instances it will
                  eliminate the  CT nodes but most of the time it does nothing
                  Chuck
                  • 7. Re: CS5 ... can't crop
                    acresofgreen Level 4
                    Chuck
                    In my version of Photoshop it is not an X, but a crossed-through circle, I think this is what Noel meant.  Clicking it should abort the crop action and remove the selection.  I have no idea why this isn't working for you.  Have you tried re-setting your Photoshop preferences to their defaults?  I don't know if it would help in your case, but it seems to be a widely recommended action for all sorts of mysterious Photoshop behavior.  You can find a description of how to reset the preferences in many threads, including here: http://forums.adobe.com/message/3938943#3938943
                    • 8. Re: CS5 ... can't crop
                      Chuckmg Level 1
                      >created by <http://forums.adobe.com/people/acresofgreen>acresofgreen
                      ><http://forums.adobe.com/message/3949396#3949396>View the full
                      >discussion
                      • 9. Re: CS5 ... can't crop
                        It seems to me, based on your clarifications, that you're running into a bona fide problem (opposed to operating Photoshop improperly, which unfortunately sometimes does happen).
                        It might just be a problem with display updates...  Try temporarily disabling OpenGL Drawing in the Edit - Preferences - Performance dialog (and restarting Photoshop before testing).  If this corrects the problem, then you very likely need a display driver update - visit the web site of the maker of your video card and download/install their latest driver.  Remember to re-enable OpenGL afterward.
                        Here's more info on OpenGL and Photoshop's use of your GPU:
                        http://kb2.adobe.com/cps/404/kb404898.html
                        http://kb2.adobe.com/cps/405/kb405745.html
                        -Noel
                        P.S., Sorry, I did mean the circle with line through it, not X.
                        • 10. Re: CS5 ... can't crop
                          spruceland
                          I can't crop either. I prepare my photos in RAW and then as a psd, I crop and the photo disappears. Does the same thing if I do it in jpg. I can retrieve the photo by going back so it's not lost. What I get is a blank screen on my desktop. When I look at the little box at the right in layers, the box is dark gray. Have I enabled something without realizing it or blocked something? Please advise. I love my CS5 and hate to have it not working.
                          ~ Eileen
                          • 11. Re: CS5 ... can't crop
                            3n31h3m
                            Photoshop cannot crop and cannot do anything ?
                            First : DO reset all preference to default setting
                            Please set your photoshop performance ====>> Enable Open GL====>>Advance====>>>OPenGL Mode ----->> Set Mode to Basic
                            And Should be work !!
