4 Replies Latest reply on Oct 3, 2011 2:46 PM by lasvideo
    Possible bug with Mocha for AE 2.6.1 and  AE 5.5 10.5.1.2
    lasvideo Level 4
      After years of using (and beta testing) Mocha, I bumped into what seems to be a bug that affects motion bur on the versions listed in the title bar.
      1. I am using Tutorial #2 (Curious Turtle) as a quick refresher.
      2. I track a small square/image on a contact sheet. Then display  and line up the surface corners.
      3. Tracking is modified  with Adjust Track so surface tracks perfectly
      4. I then output the corner pin data in 2 different ways
          a. After Effects Corner Pin only, supports RG Warp and MochaImport
          b. After Effects Corner Pin, supports motion blur
      5. The results when an image is compositied to the contact sheet backround using the tracking info follows:
          a. Using Mochaimport / CP Power point mode  with (After Effects Corner Pin only, supports RG Warp and MochaImport) - image tracks perfectly with background, but turning on motion blur and changing parameters yields no motion blur
          b. Using Mochaimport /CP Power point mode with (After Effects Corner Pin, supports motion blur). the image starts correctly but drifts  displaced over time.  If I turn on motion blur i see it shift slightly up and to the right.
      6. I also tried opening up the After Effects Corner Pin(supports motion blur ) test file, copying and pasting it on the image.The image starts correctly but drifts  displaced over time . If I turn on motion blur i see it shift slightly up and to the right.
      The current version of Mocha for AE and AE do not allow motion blur.
        • 1. Re: Possible bug with Mocha for AE 2.6.1 and  AE 5.5 10.5.1.2
          lasvideo Level 4
          Another example of a bug with the present version of Mocha for AE 2.6.1  and AE 5.5 10.5.1.2 (these problems did not exist in AE 5.0.)
          1. Tutorial #3 on Curious Turtles Rock Steady DVD
          2. Track the front of a van moving left to right on a desert road.
          3. Adjust the track.
          4. Output Transform data both to clipboard and data file
          5. Create a null and
              a. Paste transform data from clipboard. The visible track in AE is about 500 pixels  south of where it should be (tracking the front of the van)
              b. Paste transform data loaded into Mochaimport .Same problem. The visible track in AE is about 500 pixels south of where it should be (tracking the front of the van)
          6. This bug makes AE 5.5  unusable for projects that need Mocha tracking. AE 5.0 did not manifest this problem.
          • 2. Re: Possible bug with Mocha for AE 2.6.1 and  AE 5.5 10.5.1.2
            lasvideo Level 4
            UPDATE...
            After continued testing this displacement problem seems to only occurs when Progressive footage is misidentified as Interlaced.
            • 3. Re: Possible bug with Mocha for AE 2.6.1 and  AE 5.5 10.5.1.2
              Todd_Kopriva Level 8
              Tom,
              I just talked with one of the mocha product specialists at Imagineer. They think that it might be a mocha bug. If you bring the issue to their forum, they can help you there:
              http://forum.imagineersystems.com/forumdisplay.php?f=55
              (No, this is not a brush-off. It's just easier for them to deal with issues on their own forum. They'll loop me back in if it turns out to be a bug on our side.)
              • 4. Re: Possible bug with Mocha for AE 2.6.1 and  AE 5.5 10.5.1.2
                lasvideo Level 4
                Hi Todd. Thanks for responding. Yes, Ive "been there, done that" over the weekend. I posted a detailed message on that board about the 2 issues I bumped into boning up on Mocha.The displacement issue is related to misinterpreting a Progressive image as Interlaced.
                The issue where tracking images in AE that dont respond to AE motion blur ...well the jury is still out on that. Im stumped because I can take an image and move it around in AE and see motion blur respond, but when I paste
                transform tracking info to a layer that is tracking a background plate, I dont see motion blur. I do remember this working in 5.0 so hence my confusion.
