0 Replies Latest reply on Oct 1, 2011 10:17 PM by RAhatSyedAli
    Problem with Flex Builder 3
    RAhatSyedAli
      I had Flash Builder 4.5 already installed on my System. I tried to install Flex Builder 3 on my system but at the time of loading Flex Builder 3, it gives me following error:
      "An error has occured. See the log file."
      The log file showed following messages:
      !SESSION 2011-10-02 08:39:32.388 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.5.0_11
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86
      !ENTRY org.eclipse.core.runtime 4 0 2011-10-02 08:39:32.878
      !MESSAGE
      !STACK 0
      org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.equinox.preferences; bundle-version="[3.2.0,4.0.0)"
      at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:305)
      at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:350)
      at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1118)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManage r.java:634)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java :508)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelMana ger.java:282)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManage r.java:468)
      at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:195)
      at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:297)
      !ENTRY org.eclipse.osgi 4 0 2011-10-02 08:39:32.878
      !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.3.100.v20070530.jar/ was not resolved.
      !ENTRY org.eclipse.osgi 4 0 2011-10-02 08:39:32.893
      !MESSAGE Application error
      !STACK 1
      java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:72)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
      !ENTRY org.eclipse.osgi 2 0 2011-10-02 08:39:32.939
      !MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.ui.ide.application_1.0.0.I20070530-0100.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.ide.application 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.ui_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.core.resources_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.ide_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.core.ui_1.0.0.200706151.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.core.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.ui.navigator_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping.ui_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.core.resources_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.importer.rose_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.importer.rose 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh2_3.2.100.I20070604.jar was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.team.core_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.team.cvs.core_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.swt_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.team.ui_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.plan_1.0.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.plan 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.ui.dse_1.0.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.ui.dse 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.ltk.core.refactoring_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.help_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.ide_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.db.generic.ui_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.db.generic.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.emf.codegen.ecore_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.codegen.ecore 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.jsch.ui_1.0.1.r33x_20070709.jar was not resolved.
      !SUBENTRY 2 org.eclipse.jsch.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.ui_0.0.0.
      !MESSAGE Bundle update@plugins/org.eclipse.emf.codegen.ui_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.codegen.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.sybase_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.sybase 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.template.ui_3.0.4.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.template.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.pde.ui_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.tabledataeditor_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.tabledataeditor 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.ui.intro.universal_3.2.100.v20070530A/ was not resolved.
      !SUBENTRY 2 org.eclipse.ui.intro.universal 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.help_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.update.scheduler_3.2.100.v20070615.jar was not resolved.
      !SUBENTRY 2 org.eclipse.update.scheduler 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.help_1.5.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.help 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.help_0.0.0.
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.debugger.core_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.debugger.core 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.debug.ui_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.debug.core_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.console_[3.1.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.db.derby_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.db.derby 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.core.resources.compatibility_3.2.100.v20070502.jar was not resolved.
      !SUBENTRY 2 org.eclipse.core.resources.compatibility 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing host org.eclipse.core.resources_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.externaltools_3.1.200.v20070416.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.externaltools 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.jdt.core_3.3.1.v_780_R33x.jar was not resolved.
      !SUBENTRY 2 org.eclipse.jdt.core 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.routineeditor_1.0.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.routineeditor 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.ui.forms_3.3.0.v20070511.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.forms 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.jface_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20070319-0010/ was not resolved.
      !SUBENTRY 2 org.eclipse.ui.workbench.compatibility 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing host org.eclipse.ui.workbench_[3.0.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity_1.0.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.core.contenttype_3.2.100.v20070319.jar was not resolved.
      !SUBENTRY 2 org.eclipse.core.contenttype 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.equinox.preferences_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.fe.ui_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.fe.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.emf.edit.ui_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.edit.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.ui.views_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.workbench_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping.ecore2ecore.editor_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping.ecore2ecore.editor 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.postgresql.profile_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.postgresql.profile 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.core.resources.win32_3.3.0.v20070226.jar was not resolved.
      !SUBENTRY 2 org.eclipse.core.resources.win32 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing host org.eclipse.core.resources_[3.3.0,3.4.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.data.ui_1.0.0.200706151.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.data.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.jface.text_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh_3.2.100.I20061208.jar was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ssh 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.team.core_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.team.cvs.core_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping.ecore2xml.ui_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping.ecore2xml.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.jdt.launching_3.3.1.v20070808_r331.jar was not resolved.
      !SUBENTRY 2 org.eclipse.jdt.launching 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.debug.core_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.navigator.resources_3.3.1.M20070831-2000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.navigator.resources 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.ui.navigator_[3.2.1,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.workbench.texteditor_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.jdt.debug_3.3.1.v20070719_r331/ was not resolved.
      !SUBENTRY 2 org.eclipse.jdt.debug 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.ui_1.0.0.200706211.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.gef_3.2.100.v20070620.jar was not resolved.
      !SUBENTRY 2 org.eclipse.gef 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.ui.workbench_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.codegen_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.codegen 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.tablewizard_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.tablewizard 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.core.resources_[3.2.0,3.4.0).
      !MESSAGE Missing required bundle org.eclipse.ui_[3.2.0,3.4.0).
      !MESSAGE Missing required bundle org.eclipse.ui.ide_[3.2.0,3.4.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.flatfile.ui_3.0.4.200706191.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.flatfile.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.emf.importer.java_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.importer.java 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.core_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.core 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.db.generic_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.db.generic 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.common.ui_1.0.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.common.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.help.base_3.3.1.v20070813_33x.jar was not resolved.
      !SUBENTRY 2 org.eclipse.help.base 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.sqleditor_1.0.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.sqleditor 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.ui.editors_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.search_3.3.1.r331_v20070831-0800.jar was not resolved.
      !SUBENTRY 2 org.eclipse.search 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.jface.text_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.workbench.texteditor_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.draw2d_3.2.100.v20070529.jar was not resolved.
      !SUBENTRY 2 org.eclipse.draw2d 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.emf.importer_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.importer 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.jsch.core_1.0.0.I20070426.jar was not resolved.
      !SUBENTRY 2 org.eclipse.jsch.core 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.derby.ui_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.derby.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.db.generic_1.0.0.200706131.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.db.generic 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.oda.xml.ui_1.0.1.200706191.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.oda.xml.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.modelbase.derby_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.modelbase.derby 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.ui.browser_3.2.100.v20070524A.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.browser 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.msft.sqlserver.profile_1.0.0.200706151.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.msft.sqlserver.profile 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.emf.importer.ecore_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.importer.ecore 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.ui.views.properties.tabbed_3.3.1.M20070831-0800.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.views.properties.tabbed 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.sqlscrapbook_1.0.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.sqlscrapbook 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.editor.core_1.0.0.200706131.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.editor.core 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ui_3.3.1.r33x_20070807.jar was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Missing required bundle org.eclipse.compare_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.navigator_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.console_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.hsqldb_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.hsqldb 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.update.ui_3.2.100.v20070615.jar was not resolved.
      !SUBENTRY 2 org.eclipse.update.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.editor_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ecore.editor 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.db.derby_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.db.derby 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.design.ui_3.0.4.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.design.ui 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.ui.net_1.0.0.I20070516.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.net 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.fe.ui.actions_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.fe.ui.actions 2 0 2011-10-02 08:39:32.939
      !MESSAGE Bundle update@plugins/org.eclipse.ui.intro_3.2.101.v20070827_33x.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.intro 2 0 2011-10-02 08:39:32.939
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.result_1.0.0.200706181.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.result 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.oda.ws.ui_1.0.0.200706151.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.oda.ws.ui 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.oda.cshelp_1.0.0.200706191.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.oda.cshelp 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.server.ui_1.0.0.200706121.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.server.ui 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.ui.presentations.r21_3.2.100.I20070605-0010.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.presentations.r21 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.emf.common.ui_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.common.ui 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.platform.doc.user_3.3.0.M20070913-1400.jar was not resolved.
      !SUBENTRY 2 org.eclipse.platform.doc.user 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.derby_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.derby 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.emf.codegen.ecore.ui_2.3.0.v200706262000.jar was not resolved.
      !SUBENTRY 2 org.eclipse.emf.codegen.ecore.ui 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.sql_1.0.0.200706111.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.sql 2 0 2011-10-02 08:39:32.954
      !MESSAGE Bundle update@plugins/org.eclipse.ui.win32_3.2.100.I20070319-0010.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.win32 2 0 2011-10-02 08:39:32.954
      !MESSAGE Missing host org.eclipse.ui.ide_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.sybase.asa_1.0.0.200706071.jar was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.sybase.asa 2 0 2011-10-02 08:39:32.954
      !SUBENTRY 2 org.eclipse.core.runtime 2 0 2011-10-02 08:39:32.954
      !ENTRY org.eclipse.osgi 2 0 2011-10-02 08:39:32.969
      !MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.3.100.v20070530.jar/ [3] was not resolved.
      !SUBENTRY 2 org.eclipse.core.runtime 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.contenttype_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ant.core_3.1.200.v20070522.jar [17] was not resolved.
      !SUBENTRY 2 org.eclipse.ant.core 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.variables_[3.1.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.core.runtime_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.core.contenttype_3.2.100.v20070319.jar [20] was not resolved.
      !SUBENTRY 2 org.eclipse.core.contenttype 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.core.expressions_3.3.0.v20070606-0010.jar [23] was not resolved.
      !SUBENTRY 2 org.eclipse.core.expressions 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.runtime_[3.1.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.core.filebuffers_3.3.1.r331_v20070829.jar [24] was not resolved.
      !SUBENTRY 2 org.eclipse.core.filebuffers 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.core.resources_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.core.net_1.0.1.r33x_20070709.jar [28] was not resolved.
      !SUBENTRY 2 org.eclipse.core.net 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.runtime_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.core.resources.compatibility_3.2.100.v20070502.jar [29] was not resolved.
      !SUBENTRY 2 org.eclipse.core.resources.compatibility 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.core.resources.win32_3.3.0.v20070226.jar [30] was not resolved.
      !SUBENTRY 2 org.eclipse.core.resources.win32 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.core.runtime.compatibility_3.1.200.v20070502.jar [33] was not resolved.
      !SUBENTRY 2 org.eclipse.core.runtime.compatibility 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.core.variables_3.2.0.v20070426.jar [35] was not resolved.
      !SUBENTRY 2 org.eclipse.core.variables 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.db.derby_1.0.0.200706071.jar [36] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.db.derby 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity_[0.9.1,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.ui_[0.9.1,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.db.generic_[0.9.1,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.db.generic.ui_[0.9.1,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core_[0.9.1,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.help_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.help.base_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.db.generic.ui_1.0.0.200706071.jar [37] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.db.generic.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.db.generic_1.0.0.200706071.jar [38] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.db.generic 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.derby.ui_1.0.0.200706071.jar [41] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.derby.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.common_[2.2.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core.ui_[0.9.1,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.server.ui_[0.9.1,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.2.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.sql_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.derby_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.derby_[0.9.1,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.derby_1.0.0.200706071.jar [42] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.derby 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.dbdefinition_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.consumer_3.1.0.200706071.jar [43] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.consumer 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda_[3.1.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.design.ui_3.0.4.200706071.jar [44] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.design.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.ui_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.profile_[3.0.4,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design_[3.0.4,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.design_3.0.4.200706071.jar [45] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.design 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.ecore.xmi_[2.2.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.flatfile.ui_3.0.4.200706191.jar [46] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.flatfile.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.design.ui_[3.0.4,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.flatfile_[3.0.4,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.flatfile_3.0.4.200706071.jar [47] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.flatfile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.datatools.connectivity.oda.profile_[3.0.4,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.profile_3.0.4.200706071.jar [48] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.oda.consumer_[3.1.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda.template.ui_3.0.4.200706071.jar [49] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda.template.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.oda_3.1.0.200706071.jar [50] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.oda 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.core.ui_1.0.0.200706151.jar [51] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.core.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.help.base_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.core_1.0.0.200706071.jar [52] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.core 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.fe.ui.actions_1.0.0.200706071.jar [53] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.fe.ui.actions 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.server.ui_[1.0.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.sql_[1.0.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.fe.ui_[1.0.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core.ui_[1.0.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.fe.ui_1.0.0.200706071.jar [54] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.fe.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core_[1.0.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.sqm.server.ui_1.0.0.200706121.jar [55] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.sqm.server.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.sql.edit_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.emf.edit.ui_[2.2.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.ui.dse_1.0.0.200706181.jar [56] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.ui.dse 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.ui.views.properties.tabbed_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.navigator.resources_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.help_[0.9.1,2.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity.ui_1.0.0.200706211.jar [57] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.expressions_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.connectivity_1.0.0.200706181.jar [58] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.connectivity 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.hsqldb_1.0.0.200706071.jar [61] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.hsqldb 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity_[1.0.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.dbdefinition_[1.0.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.ui_[1.0.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.db.generic_[1.0.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.db.generic.ui_[1.0.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.ibm.db2.iseries.profile_1.0.0.200706071.ja r [63] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.ibm.db2.iseries.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.ui_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.ibm.db2.luw.profile_1.0.0.200706071.jar [65] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.ibm.db2.luw.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.ibm.db2.zseries.profile_1.0.0.200706071.ja r [67] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.ibm.db2.zseries.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.ibm.informix.profile_1.0.0.200706071.jar [69] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.ibm.informix.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.msft.sqlserver.profile_1.0.0.200706151.jar [71] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.msft.sqlserver.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.runtime_0.0.0.
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.sql_0.0.0.
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core_0.0.0.
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity_0.0.0.
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.mysql.profile_1.0.0.200706071.jar [73] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.mysql.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.mysql_1.0.0.200706071.jar [74] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.mysql 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.oda.ws.ui_1.0.0.200706151.jar [75] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.oda.ws.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.enablement.oda.ws_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.enablement.oda.xml.ui_[1.0.1,2.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.oda.ws_1.0.0.200706151.jar [76] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.oda.ws 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.enablement.oda.xml_[1.0.1,2.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.oda.xml.ui_1.0.1.200706191.jar [77] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.oda.xml.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.oda.xml_1.0.1.200706151.jar [78] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.oda.xml 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.oracle.profile_1.0.0.200706151.jar [80] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.oracle.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.postgresql.profile_1.0.0.200706071.jar [82] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.postgresql.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.sybase.asa.models_1.0.0.200706071.jar [83] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.sybase.asa.models 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.sql_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.enablement.sybase_[1.0.0,2.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.sybase.asa_1.0.0.200706071.jar [84] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.sybase.asa 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.db.generic_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.db.generic.ui_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core.ui_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.server.ui_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.dbdefinition_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.enablement.sybase.asa.models_[1.0.0,2.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.sybase.ase.profile_1.0.0.200706071.jar [86] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.sybase.ase.profile 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.enablement.sybase_1.0.0.200706071.jar [87] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.enablement.sybase 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.help_1.5.0.200706181.jar [88] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.help 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.modelbase.dbdefinition_1.0.0.200706071.jar [90] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.modelbase.dbdefinition 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.modelbase.derby_1.0.0.200706071.jar [91] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.modelbase.derby 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.modelbase.sql.edit_1.0.0.200706071.jar [92] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.modelbase.sql.edit 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.edit_[2.2.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.ecore.edit_[2.2.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.modelbase.sql.query_1.0.0.200706151.jar [93] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.modelbase.sql.query 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.modelbase.sql.xml.query_1.0.0.200706151.jar [94] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.modelbase.sql.xml.query 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.sql.query_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.modelbase.sql_1.0.0.200706071.jar [95] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.modelbase.sql 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.ecore.sdo_[2.2.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.oda.cshelp_1.0.0.200706191.jar [96] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.oda.cshelp 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.runtime.compatibility_[3.1.100,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.common.ui_1.0.0.200706181.jar [97] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.common.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.data.core_1.0.0.200706151.jar [98] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.data.core 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.data.ui_1.0.0.200706151.jar [99] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.data.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.core.ui_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.server.ui_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.data.core_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.result_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.tabledataeditor_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.db.derby_1.0.0.200706071.jar [100] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.db.derby 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.editor.core_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.sql_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.db.generic_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.routineeditor_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.sqleditor_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.db.generic_1.0.0.200706131.jar [101] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.db.generic 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.debugger.core_1.0.0.200706071.jar [102] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.debugger.core 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.common.ui_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.editor.core_1.0.0.200706131.jar [103] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.editor.core 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.db.generic_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.plan_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.db.generic.ui_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.result_[0.9.0,1.5.0].
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.parsers.sql.lexer_1.0.0.200706161.jar [104] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.parsers.sql.lexer 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.parsers.sql.query_1.0.0.200706162.jar [105] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.parsers.sql.query 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.parsers.sql_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.parsers.sql.lexer_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.parsers.sql.xml.query_1.0.0.200706151.jar [106] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.parsers.sql.xml.query 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.parsers.sql.query_[0.9.0,1.5.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.modelbase.sql.xml.query_[0.9.0,1.5.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.parsers.sql_1.0.0.200706161.jar [107] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.parsers.sql 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.plan_1.0.0.200706181.jar [108] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.plan 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.draw2d_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.result_1.0.0.200706181.jar [109] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.result 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.routineeditor_1.0.0.200706181.jar [110] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.routineeditor 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.sqleditor_1.0.0.200706181.jar [111] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.sqleditor 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.sqlscrapbook_1.0.0.200706181.jar [112] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.sqlscrapbook 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.sql_1.0.0.200706111.jar [113] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.sql 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.tabledataeditor_1.0.0.200706071.jar [114] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.tabledataeditor 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.datatools.sqltools.tablewizard_1.0.0.200706071.jar [115] was not resolved.
      !SUBENTRY 2 org.eclipse.datatools.sqltools.tablewizard 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.runtime_[3.2.0,3.4.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.sqleditor_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.sqltools.editor.core_[1.0.0,2.0.0).
      !MESSAGE Missing required bundle org.eclipse.datatools.connectivity.sqm.fe.ui_[1.0.0,2.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.draw2d_3.2.100.v20070529.jar [116] was not resolved.
      !SUBENTRY 2 org.eclipse.draw2d 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ant_2.3.0.v200706262000.jar [117] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ant 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.ant.core_[3.1.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.common_[2.3.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.codegen_[2.3.0,3.0.0).
      !MESSAGE Missing optionally required bundle org.eclipse.emf.codegen.ecore_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.codegen.ecore.ui_2.3.0.v200706262000.jar [118] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.codegen.ecore.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.jdt.core_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.codegen.ecore_[2.3.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.edit.ui_[2.3.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.ecore.edit_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.codegen.ecore_2.3.0.v200706262000.jar [119] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.codegen.ecore 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.jdt.launching_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.ecore_[2.3.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.ecore.xmi_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.codegen.ui_2.3.0.v200706262000.jar [120] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.codegen.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.common.ui_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.codegen_2.3.0.v200706262000.jar [121] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.codegen 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.common.ui_2.3.0.v200706262000.jar [122] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.common.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.core.resources_[3.3.0,4.0.0).
      !MESSAGE Missing optionally required bundle org.eclipse.ui.ide_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.commonj.sdo_2.3.0.v200706262000.jar [123] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.commonj.sdo 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.common_2.3.0.v200706262000.jar [124] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.common 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.converter_2.3.0.v200706262000.jar [125] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.converter 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.emf.codegen.ecore.ui_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.change.edit_2.3.0.v200706262000.jar [126] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ecore.change.edit 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.ecore.change_[2.3.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.edit_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.change_2.3.0.v200706262000.jar [127] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ecore.change 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.editor_2.3.0.v200706262000.jar [128] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ecore.editor 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.edit_2.3.0.v200706262000.jar [129] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ecore.edit 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.sdo_2.3.0.v200706262000.jar [130] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ecore.sdo 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.commonj.sdo_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ecore.xmi_2.3.0.v200706262000.jar [131] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ecore.xmi 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.ecore_2.3.0.v200706262000.jar [132] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.ecore 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.edit.ui_2.3.0.v200706262000.jar [133] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.edit.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.edit_2.3.0.v200706262000.jar [134] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.edit 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.emf.ecore.change_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.exporter_2.3.0.v200706262000.jar [135] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.exporter 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.converter_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.importer.ecore_2.3.0.v200706262000.jar [136] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.importer.ecore 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.importer_[2.3.0,3.0.0).
      !MESSAGE Missing optionally required bundle org.eclipse.emf.ant_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.importer.java_2.3.0.v200706262000.jar [137] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.importer.java 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.importer.rose_2.3.0.v200706262000.jar [138] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.importer.rose 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.importer_2.3.0.v200706262000.jar [139] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.importer 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping.ecore2ecore.editor_2.3.0.v200706262000.jar [141] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping.ecore2ecore.editor 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.mapping.ecore2ecore_[2.3.0,3.0.0).
      !MESSAGE Missing required bundle org.eclipse.emf.mapping.ui_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping.ecore2ecore_2.3.0.v200706262000.jar [142] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping.ecore2ecore 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.mapping_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping.ecore2xml.ui_2.3.0.v200706262000.jar [143] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping.ecore2xml.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.emf.mapping.ecore2xml_[2.3.0,3.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping.ecore2xml_2.3.0.v200706262000.jar [144] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping.ecore2xml 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping.ui_2.3.0.v200706262000.jar [146] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.emf.mapping_2.3.0.v200706262000.jar [147] was not resolved.
      !SUBENTRY 2 org.eclipse.emf.mapping 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.gef_3.2.100.v20070620.jar [156] was not resolved.
      !SUBENTRY 2 org.eclipse.gef 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.ui.views_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.help.appserver_3.1.200.v20070510.jar [157] was not resolved.
      !SUBENTRY 2 org.eclipse.help.appserver 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.help.base_3.3.1.v20070813_33x.jar [158] was not resolved.
      !SUBENTRY 2 org.eclipse.help.base 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.ant.core_3.1.0.
      !MESSAGE Missing required bundle org.eclipse.core.runtime_3.3.0.
      !MESSAGE Bundle update@plugins/org.eclipse.jdt.core_3.3.1.v_780_R33x.jar [159] was not resolved.
      !SUBENTRY 2 org.eclipse.jdt.core 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.team.core_[3.1.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.jdt.debug_3.3.1.v20070719_r331/ [160] was not resolved.
      !SUBENTRY 2 org.eclipse.jdt.debug 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.expressions_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.jdt.launching_3.3.1.v20070808_r331.jar [161] was not resolved.
      !SUBENTRY 2 org.eclipse.jdt.launching 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.jdt.debug_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.core.variables_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.jsch.core_1.0.0.I20070426.jar [162] was not resolved.
      !SUBENTRY 2 org.eclipse.jsch.core 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.net_[1.0.0,2.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.jsch.ui_1.0.1.r33x_20070709.jar [163] was not resolved.
      !SUBENTRY 2 org.eclipse.jsch.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.jsch.core_0.0.0.
      !MESSAGE Bundle update@plugins/org.eclipse.platform.doc.user_3.3.0.M20070913-1400.jar [166] was not resolved.
      !SUBENTRY 2 org.eclipse.platform.doc.user 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.search_3.3.1.r331_v20070831-0800.jar [167] was not resolved.
      !SUBENTRY 2 org.eclipse.search 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.core.filebuffers_[3.3.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.ui.forms_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh2_3.2.100.I20070604.jar [168] was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.team.cvs.ssh_[3.2.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.jsch.core_[1.0.0,2.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh_3.2.100.I20061208.jar [169] was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ssh 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ui_3.3.1.r33x_20070807.jar [170] was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ui 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.jface.text_[3.3.0,4.0.0).
      !MESSAGE Missing optionally required bundle org.eclipse.ui.workbench.texteditor_[3.3.0,4.0.0).
      !MESSAGE Missing optionally required bundle org.eclipse.ui.editors_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.tomcat_4.1.230.v20070531/ [172] was not resolved.
      !SUBENTRY 2 org.eclipse.tomcat 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing required bundle org.eclipse.help.appserver_[3.1.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.browser_3.2.100.v20070524A.jar [173] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.browser 2 0 2011-10-02 08:39:32.969
      !MESSAGE Bundle update@plugins/org.eclipse.ui.externaltools_3.1.200.v20070416.jar [174] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.externaltools 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.ui.ide_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.forms_3.3.0.v20070511.jar [175] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.forms 2 0 2011-10-02 08:39:32.969
      !MESSAGE Missing optionally required bundle org.eclipse.ui_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.ide.application_1.0.0.I20070530-0100.jar [176] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.ide.application 2 0 2011-10-02 08:39:32.969
      !SUBENTRY 2 org.eclipse.ui.ide.application 2 0 2011-10-02 08:39:32.985
      !MESSAGE Missing required bundle org.eclipse.ui.navigator.resources_[3.2.100,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.update.core_[3.1.100,4.0.0).
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-10-02 08:39:32.985
      !MESSAGE Bundle update@plugins/org.eclipse.ui.intro.universal_3.2.100.v20070530A/ [177] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.intro.universal 2 0 2011-10-02 08:39:32.985
      !MESSAGE Missing required bundle org.eclipse.ui.intro_[3.2.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.intro_3.2.101.v20070827_33x.jar [178] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.intro 2 0 2011-10-02 08:39:32.985
      !MESSAGE Bundle update@plugins/org.eclipse.ui.navigator.resources_3.3.1.M20070831-2000.jar [179] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.navigator.resources 2 0 2011-10-02 08:39:32.985
      !MESSAGE Bundle update@plugins/org.eclipse.ui.net_1.0.0.I20070516.jar [180] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.net 2 0 2011-10-02 08:39:32.985
      !MESSAGE Bundle update@plugins/org.eclipse.ui.presentations.r21_3.2.100.I20070605-0010.jar [181] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.presentations.r21 2 0 2011-10-02 08:39:32.985
      !MESSAGE Bundle update@plugins/org.eclipse.ui.views.properties.tabbed_3.3.1.M20070831-0800.jar [182] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.views.properties.tabbed 2 0 2011-10-02 08:39:32.985
      !MESSAGE Missing required bundle org.eclipse.ui.forms_[3.3.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.win32_3.2.100.I20070319-0010.jar [183] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.win32 2 0 2011-10-02 08:39:32.985
      !MESSAGE Bundle update@plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20070319-0010/ [184] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.workbench.compatibility 2 0 2011-10-02 08:39:32.985
      !MESSAGE Bundle update@plugins/org.eclipse.update.core.win32_3.2.100.v20070615.jar [186] was not resolved.
      !SUBENTRY 2 org.eclipse.update.core.win32 2 0 2011-10-02 08:39:32.985
      !MESSAGE Missing host org.eclipse.update.core_[3.0.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.update.core_3.2.101.R33x_v20070911.jar [187] was not resolved.
      !SUBENTRY 2 org.eclipse.update.core 2 0 2011-10-02 08:39:32.985
      !MESSAGE Bundle update@plugins/org.eclipse.update.scheduler_3.2.100.v20070615.jar [188] was not resolved.
      !SUBENTRY 2 org.eclipse.update.scheduler 2 0 2011-10-02 08:39:32.985
      !MESSAGE Missing required bundle org.eclipse.update.core_[3.1.0,4.0.0).
      !MESSAGE Missing required bundle org.eclipse.update.ui_[3.1.0,4.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.update.ui_3.2.100.v20070615.jar [189] was not resolved.
      !SUBENTRY 2 org.eclipse.update.ui 2 0 2011-10-02 08:39:32.985
      Can you please help me solving this problem?
