1 Reply Latest reply on Jul 10, 2006 7:37 AM by LaoD
    cfform not working
    RyanG24 Level 1
      EDIT > I have just noticed that none of my cfform required attributes work, they work on my local machine but not on my hosting companys, any ideas?
      Hi i have this form below which i need a message to popup if the value is less than 10000 is my code correct? as the form submits without stopping the user
      also i need this same form in another area but it need to be a hidden value how would i do this?
        • 1. Re: cfform not working
          Setting "REQUIRED" to yes and validate to "INTEGER" should do the trick.
          <cfinput type="Text" name="TotalCost" value="#GetTotal.Total#" range="1,10000" message="PLEASE CHANGE YOUR TEAM \n\n Total Cost Must Be Less Than $10,000" required="yes" validate="integer">
          For the hidden value, if you are passing this input value to the next form, you would just add <cfinput type="HIDDEN" Name="TotalCost" Value="#FORM.Total#>. If you are passing this hidden value from some place other than this form, then change FORM.Total to whatever you are passing from, e.g. URL instead of FORM.
