5 Replies Latest reply on Oct 3, 2011 3:29 PM by gaphic2
    [CS5] Changing the size of linked images possible by updating source?
    gaphic2 Level 1
      In a catalog, I'm using 400 instances of 10 small labels. The labels are in a linked Illustrator file. I would like to be able to adjust the size of these labels by simply changing the source file and updating the link.
      I know Indesign is normally set up to keep the physical size of the frames intact, but I thought I could change this by a combination of File Handling options and Object Style Frame Fitting options. I've been trying various things but no success so far.
      Is this at all possible?
      Update: I can change the size of the image allright, but the frame does not follow. Do the Object Style Frame Fitting options only work the first time?
      Is there a workaround?
