2 Replies Latest reply on Oct 4, 2011 1:37 PM by JLAFARGUE
    Setting the Access of a subform
    JLAFARGUE
      I'm trying to set the access of a subform based on the value of a checkbox in another subform.    In the change event of the checkbox, if the rawValue == 1, then I attempt to set the access of the second subform to "protected".  If the rawValue == 0, I set the access of the second subform to "open".
      What actually happens is that the access of the second subform is unchanged.   In fact, when I try to even display the value of the access attribute of the second subform from the change event of the checkbox, the value displays a s null.  What am I doing wrong?
      Here's the code that sets the access:  ('this' is the checkbox.)
      if  (this.rawValue == 1) {
           parent.parent.subform2.access = "protected';
      else {
           parent.parent.subform2.access = "open";
      The hierarchy is this:
      Mainform
           subform1
                checkbox
           subform2
                < Other Objects>
      Subform2 is a repeatable subform, so when I set the access to "protected", I also want to remove all instances except the first one.
        • 1. Re: Setting the Access of a subform
          Steve L Walker Level 5
          First, what event are you coding against?
          Second, I'd recommend removing parent references in this use case and point directly at the subform.
          // form1.page1.subform1.cb::click - (JavaScript, client)
                    form1.page1.subform2.access = "protected";
          else {
                    form1.page1.subform2.access = "open";
          Steve
          • 2. Re: Setting the Access of a subform
            JLAFARGUE Level 1
            I tried removing the parent references and specifically referencing the subform but it didnt' work.  However, I did find out how to do it from a co-worker.  Here's how.
            In the checkbox change event of the checkbox  (this):
            if (this.rawValue == 1) { //1
                 var i = 0;
                 var ref = xfa.resolveNode("MainForm.PageN.Subform[" + i + "]");
                 ref.TextField.rawValue = null;                         //  repeat these two lines
                 ref.TextField.access = "protected";                //   for every field you want to reset and set unavailable.
            else {
                 ref.TextField.access = "open";                         // repeat this line for every field to set available.
            I haven't figured out how to travel through the hierarchy to do this, so I will have to set the rawValue and access for each individual field.
