11 Replies Latest reply on Oct 4, 2011 9:14 AM by petedenly
    Drop caps with a quotemark at start of para
    petedenly
      If a paragraph starts with a quote mark then I need to drop cap the SECOND character onwards. How is this done using the drop cap system or is it not possible?
      I currently remove the quote mark into another text box and position this manually.
      Any other solutions?
      Pete Denly
        • 1. Re: Drop caps with a quotemark at start of para
          You can specify any number of characters you like, as well as the number of lines to drop, in any dialog that allows you to set a drop cap, as well as in the control panel. If the drop cap is part of your style, either define a new style based on the first and change the number of characters to 2, then apply that style to paragraphs that start with quotes, or change the number for select paragraphs as a local overrride.
          • 2. Re: Drop caps with a quotemark at start of para
            petedenly Level 1
            Hi Peter,
            I don't want to drop cap the quote mark and the second character but just the second character. I have tried applying a character style to the quote mark having drop capped the first two characters to make it the same as the paragraph but this does not work.
            Pete Denly
            • 3. Re: Drop caps with a quotemark at start of para
              Sorry, misunderstood the question.
              I'm not sure what you have against enalarging the quote mark to match, but I was able to do what you want by adding a nested style (and you could do this as local override formatting, too, but I'm sure you'll want to create a character style to do it, and doing it as a nested style will allow it to disappear when you change to a style that does not drop the caps) through one character that reduces the horizontal and vertical scale, and adds some baseline shift.
              You'll need to establish the correct values through trial and error, but in my test I used Minion Pro regular, 12 pt on 14.4 autoleading, and scaling to 37% with a 14 pt baseline shift seems about right if you drop two lines.
              • 4. Re: Drop caps with a quotemark at start of para
                petedenly Level 1
                Thanks Peter,
                It's a three line drop with one character so is quite ugly with just the quote mark as this character. It is out of style if I drop cap the second character as well.
                I will try this out on the publication in question.
                Regards
                Pete Denly
                • 5. Re: Drop caps with a quotemark at start of para
                  I'm confused now. In any document I can recall that used drop caps, I'm pretty sure that a leading quote would have been dropped along with the following character. I'm not quite sure what you mean that "It is out of style if I drop cap the second character as well." Are you saying you DON'T want the character after the quote mark dropped?
                  • 6. Re: Drop caps with a quotemark at start of para
                    petedenly Level 1
                    The style of the first paragraph in each article has a drop cap of one character to the depth of three lines.
                    Sometimes that first character is a quote mark (") rather than a letter.
                    I do not want to drop cap both the quote mark and the next letter character but just the second character (if it is a letter) if the first character is a quote mark.
                    Like this (a two line example I have to hand)
                    • 7. Re: Drop caps with a quotemark at start of para
                      OK. The scaling/baseline shift trick should do what you want, once you find the correct values. Change the drop to the first 2 characters and apply the nested character syle to only the first character.
                      • 8. Re: Drop caps with a quotemark at start of para
                        Eugene Tyson Adobe Community Professional & MVP
                        You can do it with a grep style on the opening quoteY
                        You will have to play around with the char style to get it baseline shift, kerning, size etc. right
                        • 9. Re: Drop caps with a quotemark at start of para
                          David W. Goodrich Level 3
                          Sometimes you can leave out an opening quote mark before a drop cap.  A thread over on InDesign Secrets refers to the Chicago Manual, saying "the open quote is often dropped when the design calls for a drop cap" (not readily findable in my old 12th ed.).  Meanwhile, a Typophile thread cites Bringhurst on how the opening quote mark should be sized and placed to fit the cap and design, i.e., for the good of the reader.  So if you're going to use it, you are likely to have to play around to get it to look right, and settings that look right in front of a "L" might not work for an "A".
                          David
                          • 10. Re: Drop caps with a quotemark at start of para
                            BradleyML
                            And, in this example, please apply kerning between the "L" and the "i" to move "iving" left, and insert an en-space before "marks." It means just a bit of extra work to do the appropriate (differing) spacing for each drop cap, but, now, doesn't that look better?
                            Best regards,
                            Mike Bradley
                            • 11. Re: Drop caps with a quotemark at start of para
                              petedenly Level 1
                              Thanks guys for your advice and help sorting this out.
                              I have split the alphabet into four main groups and made a paragraph style each with its own character style for the quote mark. They differ in the tracking amount for the quote mark.
                              The paragraph style has drop cap set to: 3 lines 2 characters
                              Nested style: Character style through 1 Character
                              Sorted.
                              Gives me a good start and just the final adjustments to make (Thanks Bradley)
                              Regards to all
                              Pete Denly
