2 Replies Latest reply on Oct 4, 2011 8:16 AM by PaddyMc2010
    Exit an I.E Browser from Flex
    PaddyMc2010
      Hi all,
      I was wondering is there anything in flex that i can use to close an internet explorer window?  I have a menu bar that i want to use with a file/exit menu option that will unload the the entire i.e window.
      Can this be done in Flex?
      Would anyone be able to advise?
      Patrick
        • 1. Re: Exit an I.E Browser from Flex
          pjoshi_infocepts
          We can close I.E. window from flex by using JavaScript. Here is the sample code -
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                                                  layout="absolute">
            <mx:Script>
                                   <![CDATA[
                                                  public function jsCloseWindow():void
                         if (ExternalInterface.available)
                              ExternalInterface.call("closeWindow");
                    </mx:Script>
                    <mx:Button x="10" y="10" label="Close Window" click="jsCloseWindow()"/>
          </mx:Application>
          Also you need to write javascript function"closeWindow()" in "html-template\index.template.html" file to close window -
          function closeWindow()
                    window.close();
          Hope this will help you.
          I am not sure if there is any other way to achieve this from flex.
          Thanks and Best regards,
          Pallavi Joshi | pjoshi@infocepts.com | www.infocepts.com
          • 2. Re: Exit an I.E Browser from Flex
            PaddyMc2010 Level 1
            Many thanks.  Ill give this a go.
            Patrick
