7 Replies Latest reply on Nov 15, 2011 6:53 AM by The Dam Armada
    Exporting Layers to PNG files using each layer name to create the file name??
    nate_movingpixel
      Hi All
      I'm trying to sort the following problem and was hoping somebody here could help with a scripting solution - my knowledge extends as far as actions unfortunately - which I don't think is appropriate for this.
      I've created a User interface in Illustrator with many layers and have exported this as a psd with layers.
      Basically what i'm wanting to do is export every layer as a png file while using the layer name to create the file name - each layer needs to be clipped.
      There is no transparency in the png.
      I've run the export to files script - but the names are too long and there is no anti aliasing.
      I've tried running a script from Illustrator - but it doesn't see sub layers - and doesn't name the layers.
      any help would be appreciated.
      thanking you in advance
      regards
      nate
