2 Replies Latest reply on Oct 4, 2011 1:36 PM by HAL_123
    Extracting attributes from a pdf file
    HAL_123
      I would like to extract some of the information that is stored at attributes to a pdf file.
      I have seen other threads on the same subject and one suggested the use of DDX which, as far as I understand, is some kind of markup language.
      The only problem is that I do not know if that option is still available since the DDX homepage seems to have shut down a year and a half ago.
      Hence, I am not sure their products are available at the market any more and if so - which one to use (there seemed to be at least seven different products from DDX).
      Is there any other solution available which could provide the same result (i.e. an extraction of the data in the attribute fields of the pdf-file) ?
      Cheers
      /Hal
