6 Replies Latest reply on Oct 11, 2011 5:59 AM by ghouser
    Field value from form in subject line?
    ghouser
      I'm using a submit by email button on my form and was wondering if it is possible to pull the value of a filled in field on the form into the subject line of the email that is generated?  The button is using the standard "mailto" followed by a "subject=".  I would like to have the subject of the email read something like: "New request - (account number or name from form here)".
      Thanks.
        • 1. Re: Field value from form in subject line?
          Steve L Walker Level 5
          You can use a button (control type 'regular'), add a click event handler and mimic the email submit button. In this example I included a form field called 'acctNumber' and inserted the rawValue into the sublect.
          // form1.page1.subform1.mySubmitBtn::click - (JavaScript, client)
          event.target.submitForm({cURL:"mailto:jblack@localhost?subject="+acctNumber.rawValue+"&bod y=Friendly Reminder",cSubmitAs:"PDF",cCharset:"utf-8"});
          Steve
          • 2. Re: Field value from form in subject line?
            ghouser Level 1
            To be honest, I don't follow.  If I make the button a "regular" then it doesn't have the tab for putting in the email address like a mailto: button does.  The "submit" tab goes away.  And I couldn't find how to do a click event in the help files.  I was probably searching for the wrong wording.  Where would your three lines of code be placed?
            Btw, the form is a PDF that each of our sales person will have on the desktop of their laptops out in the field, so it will not reside on a server.  It seems I read something about this making a difference on what actions are available.
            The whole intent of the project is to have a form quickly available to our sales team which they simply fill in the details of what they need and it gets emailed as a PDF attachment to the appropriate buyer in our company. I would gladly share this form if you wish to see it.  By your standards it's probably a kindergarten effort, but I have to start somewhere. :-)
            • 3. Re: Field value from form in subject line?
              Take a look at the attached. It contains the script previously referenced.
              Steve
              • 4. Re: Field value from form in subject line?
                ghouser Level 1
                I don't see any script and the button has no more tabs than I wrote before. Could this be a version difference? I'm using v8.05.2703. Your example was created in a newer version, so perhaps my older version won't let me see or do what you are offering.
                • 5. Re: Field value from form in subject line?
                  The script is on the button click event.
                  If you are referring to the tabs on the object properties, they are configurable by right-clicking the dark grey space to the right of the last tab.
                  This functionality is not impacted by a newer version of Designer. This has been around since the first version of Designer and I doubt that it has changed.
                  Steve
                  • 6. Re: Field value from form in subject line?
                    ghouser Level 1
                    I thought everything with a button was done on the tabs and hadn't discovered the scripting window. I have it turned on now and understand what you were saying. Goes to show you can still learn over 50.  :-)  However the script did produce a syntax error.
