1. Re: Brush opacity shortcuts keep changing zoom level? What?
GoaliGrlTilDeath Oct 5, 2011 8:09 AM (in response to GoaliGrlTilDeath)I have discovered that the zoom is changing because it is imputting the numbers into the zoom percentage box in the lower left of the screen. In fact, my shortcuts being input there is the reason I've been having all these weird problems.... but I have no idea how to make it stop inputting everything there. Anyone have any ideas?
2. Re: Brush opacity shortcuts keep changing zoom level? What?
Jeffrey Tranberry Oct 5, 2011 7:29 PM (in response to GoaliGrlTilDeath)Hit the Esc key. That should remove focus from the zoom percentage box.
3. Re: Brush opacity shortcuts keep changing zoom level? What?
GoaliGrlTilDeath Oct 6, 2011 9:34 AM (in response to Jeffrey Tranberry)Thank you, that helps. Is there any way to keep it from putting the focus on the zoom percentage box in the first place?
4. Re: Brush opacity shortcuts keep changing zoom level? What?
Jeanne Rubbo Oct 7, 2011 12:35 PM (in response to GoaliGrlTilDeath)I'm trying to figure out why the zoom field is gaining focus unintentionally. Does this happen when you unplug your tablet and use the mouse instead? If not, that would indicate it has something to do with the tablet. Is it possible you're accidentally bumping a touch strip on the tablet that puts focus on the zoom field? You can try disabling various buttons and the touch strip(s) to see if one of these might be the culprit.
Of course, this assumes that it's a tablet settings issue. If the problem happens whether or not you're using a tablet, then we'll have to look into that further.
5. Re: Brush opacity shortcuts keep changing zoom level? What?
GoaliGrlTilDeath Oct 7, 2011 5:53 PM (in response to Jeanne Rubbo)I honestly have never used Photoshop without my tablet since installing CS5.5 so I'm not sure if it does it with the mouse (I'm pretty gimpy with a mouse so I rarely use it). I do have my touchstrip disabled and the buttons on the tablet are set to command, option, command+Z, and unassigned... though my hands are nowhere near them. I will try disabling all of the buttons as I normally don't use them and see if that changes things.
Thank you and I will let you know if the problem's persisting.
