1 Reply Latest reply on Oct 5, 2011 4:44 AM by Ned Murphy
    I know this might be lame....
    wolmah
      But here it goes, I am looking for tutorial that creates similar swf file as this url...
      http://www.honesttea.com/objects/flash/sitetop_110829.swf
      Any guidiance will help a lot!
      Eric
        • 1. Re: I know this might be lame....
          You are not likely to find a tutorial specifically for that.  What you will want to do is to look into using Actionscript tweening and filtering.  When you rollover one of the objects, you use the tweening and filtering on the remaining objects to make them move, change their alpha, and blur them, while making the opposite happen fpr the one rolled over.  When you rollout of an object you reverse the tweens.
          What you should do is search Google using terms like "AS3 Tween tutorial" or even "AS3 TweenLite tutorial" (for a third party tweening class that works better)
