6 Replies Latest reply on Oct 14, 2011 8:15 AM by clb2196@gmail.com
    Help with JSON Decoding
    clb2196@gmail.com
      Hi guys, I'm kinda a n00b to Flex, and definitely a n00b to JSON decoding, hoping you can help me out.
      I just put the very basics in this code, I want to  be able to decode the JSON from the Rotten Tomatoes link, and display it in a datagrid. I seem to be only getting the top level (I took out the datagrid colums so you can see what it populates with). I want to get the actual movie info, which is one level further down. How do I do that?
      Here's the link I'm trying to read in: http://api.rottentomatoes.com/api/public/v1.0/movies.json?apikey=u9pv54jkhnhemfx8x6u8q83r& q=Jack&page_limit=1
      And here's my full code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns="*" layout="absolute"
                                              creationComplete="service.send()">
                <mx:Script>
                          <![CDATA[
                                    import mx.collections.ArrayCollection;
                                    import mx.rpc.events.ResultEvent;
                                    import com.adobe.serialization.json.JSON;
                                    import mx.utils.*;
                                    private function onJSONLoad(event:ResultEvent):void
                                              var rawData:String = String(event.result);
                                              var info:Object = JSON.decode(rawData);
                                              var dp:ArrayCollection = new ArrayCollection(ArrayUtil.toArray(info));
                                              grid.dataProvider = dp;
                                    var urlString:String = "http://api.rottentomatoes.com/api/public/v1.0/movies.json?apikey=u9pv54jkhnhemfx8x6u8q83r& q=Jack&page_limit=1";
                </mx:Script>
                <mx:HTTPService id="service" resultFormat="text"
                                                        url= "{urlString}"
                                                        result="onJSONLoad(event)" />
                <mx:DataGrid id="grid" right="10" left="10" top="10" bottom="10">
                </mx:DataGrid>
      </mx:Application>
        • 1. Re: Help with JSON Decoding
          Raghuvasa
          I have modified Your code and placed it here. it is working fine.
                    <mx:Script>
                              <![CDATA[
                      import com.adobe.serialization.json.JSONDecoder;
                      import com.adobe.serialization.json.JSONTokenizer;
                      import mx.utils.*;
                      import mx.controls.Alert;
                          var info:Object = new JSONDecoder(rawData,true).getValue().movies as Object;
                      var urlString:String = "http://api.rottentomatoes.com/api/public/v1.0/movies.json?apikey=u9pv5                 4jkhnhemfx8x6u8q83r&q=Jack&page_limit=1";
                    </mx:Script>
                                                            url= "{urlString}"
                    <mx:DataGrid id="grid" right="10" left="10" top="10" bottom="10" >
                  <mx:columns>
                      <mx:DataGridColumn headerText="Title" dataField="title" />
                      <mx:DataGridColumn headerText="Year" dataField="year" />
                  </mx:columns>
              </mx:DataGrid>
          </mx:Application>
          And place column name which columns do want to show. And as3corelib.swc it is a library download it for jsondecoder.
          I think it would be helpful for you.
          Raghu.
          • 2. Re: Help with JSON Decoding
            clb2196@gmail.com Level 1
            Hi Raghu,
            I tried that actually, but I copied your code in exactly, and it won't compile. It says "access of undefined property movies".
            • 3. Re: Help with JSON Decoding
              Anyone else have any ideas?
              • 4. Re: Help with JSON Decoding
                Flex harUI Adobe Employee
                Run one of the objects through ObjectUtil.toString() and post it here and tell us which fields you want to show.
                • 5. Re: Help with JSON Decoding
                  I guess I'm not even understanding how the JSON object gets added to the array. How do I retrieve an individual object?
                  • 6. Re: Help with JSON Decoding
                    Hm... strange. I re-copied your code, and although I had to change var info:Object = new JSONDecoder(rawData,true) to var info:Object = new JSONDecoder(rawData) it seems to work now. I'm not sure what I did before... but thanks!
