0 Replies Latest reply on Oct 5, 2011 5:04 AM by Ralf Eversen
    Problem building swc that contains <s:SolidColor> with manifest file
    Ralf Eversen
      Hi all,
      I have a problem compiling a library with the command line compiler. The problem is that when I don't use a Manifest file, everything compiles as expected. When I specify a Manifest file for building my swc, I get an error "Could not resolve <s:SolidColor> to a component implementation".
      My library consists of one class, which is: Test.mxml
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark">
        <s:Rect x="50" y="50" width="100" height="100">
          <s:fill>
            <s:SolidColor />
          </s:fill>
        </s:Rect>
      </s:Group>
      This is my Manifest.xml
      <?xml version="1.0"?>
      <componentPackage>
                <component id="Test" class="Test"/>
      </componentPackage>
      This commands gives no error and results in a swc successfully
      compc -output TestLibrary.swf -include-classes Test -source-path .
      This commands leads to the error "Could not resolve <s:SolidColor> to a component implementation"
      compc -output TestLibrary.swf -include-classes Test -source-path . -compiler.namespaces.namespace http://test Manifest.xml -include-namespaces http://test
      I think this is the correct way of creating an swc using a Manifest file. Is this correct (so this is a bug?) or am I doing something wrong?
